Need assistance with Car Audio Question
03 Type S - 153,000 miles
I wanted to install an amp for a 10inch sub. I dont want to hook up behind the deck, i wanted to tie the RCA converter off the factory sub for an input. Is this possible ? Or will I need to use the rear speakers for 2 input signals ? I want to keep things pretty simple.
thanks
thanks
have you looked in the main stereo threads section- likely your answer is already there
I need 2 more gears
why do that? I used to have 2 12" Orion DVC's running off the stock Bose HU. You just need an adapter. A car stereo shop can hook this up for you no problem. You'll need an amp of course. What kind of sub and amp setup are you looking to run?
MechEng
okay so this is your second thread asking the same question and you still have not posted it in the appropriate section. whats goin on man?
just search. or look at the responses from your other thread.
https://acurazine.com/forums/2g-tl-1999-2003-98/car-audio-question-03-tl-s-770826/
wusty23jd
09-24-2015 11:41 AM
Hau_nguyen91
09-06-2015 12:53 PM
