Need advice for rotors
Old Sep 14, 2004 | 04:28 PM
Laffinitup's Avatar
I'm on my second set of warped rotors. Does anybody have any advice to remedy this bad situation I'm in? I only have 40k on my 02tls and this rotor problem is the worse. Everyone on this site is pretty good about helping out so I know someone will be able to give me some helpful advice.
Old Sep 14, 2004 | 05:19 PM
dj5's Avatar
dj5
Replace the front rotors with Rotora slotted rotors. Check out www.streetbeatcustomes.com. A lot of people also replace their pads with Axxis Ulimates or EBC Greenstuff.
Old Sep 14, 2004 | 08:26 PM
TypeSDragon's Avatar
Loving my 08 TLS!
Go aftermarket for sure. I got mine from irotors.com and have put more than 25k miles and they are still holding up well. Make the investment and you won't have to worry about this warp rotor bullshit.
Old Sep 15, 2004 | 05:47 AM
seahawk's Avatar
I invested in a torque wrench a while back. Having even pressure on the lug-nuts is
important. Look up setting in manual, not sure if it's 60 or 80 lbs.
Old Sep 15, 2004 | 07:47 AM
Faizalstar's Avatar
TLStar
correction:
www.streetbeatcustoms.com
Old Sep 15, 2004 | 08:52 AM
stiletto's Avatar
I just placed an opinin that claims a TSB number for the brake issue... http://www.acura-tl.com/forums/showthread.php?t=94409 In addition, there was a really nice article that will certainly enlighten you mentioned by JRitt@stoptech http://www.acura-tl.com/forums/showthread.php?t=94411
Old Sep 15, 2004 | 09:03 AM
NSXNEXT's Avatar
It's 80 lbs and yes that is a very good suggestion. I never let a mechanic take a impact wrench to my lugs.
Old Sep 15, 2004 | 09:27 AM
Laffinitup's Avatar
You guys are awesome. Thanks alot. Sucks to pay 30k for your car and have a reaccuring problem like this one.
Old Sep 15, 2004 | 10:12 AM
NYZGREATST's Avatar
Sig Rho's Finest
i also went with aftermarket rotora slotted rotors and ebc greenstuff pads. ths cost justified the means by a long shot. resurfacing the stock rotors will just give a temp solution
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
soupi
14
Nov 15, 2015 11:15 AM
