my suspension is creeking and squeeking--help!
so ever since i lowered my TL, i've been getting these annoying noises coming from the right side of my car. i searched this problem up already and i lubed up all the joint with WD-40. this helps for a while and then the squeeking and creeking comes back next day. also, this only happens when i'm going over a dump or dip in the road at 40mph or less, and when i'm on the freeway it's quiet. what do i need to do to fix this? thanks in advance!
cliffs:
- lowered my car (ground-controls)
- the suspension on the right side squeeks
- only squeeks when i'm going at lower speeds
cliffs:
its most likely your shock, how many miles on them? on a lowered car u should replace the shocks with aftermarket shocks. and its also faster that way, bc now u have to take everything apart.
what do you mean misalignment? like the spring is not sitting flat on the perch? my rear-right spring is now the only one squeeking, i jacked up the car almost 3 times already to reposition the spring but it only helps for a while. i think maybe i didn't screw the bolts on tightly on the shock tower in the rear because when i lowered my car, i might've gotten to excited and impatient so i half-assed bolting something down.
which part of my suspension? can you be more specific? thanks. the problem is now only concentrated on my rear, right suspension. i noticed that every time i readjust the spring, it remains quiet until i have passenger(s), then it starts to squeek again. i'm getting really frustratedddd so help please!
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
adreano17
09-29-2015 08:48 AM
MrHeeltoe
09-28-2015 05:43 PM
