My piaa fog light crack~anyone has same prob?
I just bought my piaa fog light two months ago, and the model # is (912 Stealth). Yesterday when I drove to SD during the rain and I found out my foglight lens crack~ what the heck..I just bought it for two months..what should I do? Does anyone has the same problem? Y is the light so expensive and so easy to crack? me so
Re: My piaa fog light crack~anyone has same prob?
go to a shop that you know and ask about those fog lights. If you just need to replace the glass then that's cool. If you need to replace the entire housing (PIAAs are usually like that) then there will be some BigMoneyWasted.
The New 3 Series Coupe
Re: Re: My piaa fog light crack~anyone has same prob?
Originally posted by bioyuki
Cracked fogs are pretty common because they are so low to the ground. If something hits it at freeway speeds its very likely to break. You can protect your investments in the future by putting Xpel over the lights. As for the cracked lens I would get it fixed.
PIAA fog lights
I had the same exact problem, except it was with the PIAA 1700 series lamps. It cracked about 3 months later. I called PIAA directly and told them what happened. The rep tried to tell me it was probably hit by a rock while driving or that I installed it incorrectly. So, I sent it back to them for them to see for themselves. They determined that the cracks were caused by the winter weather(I live in NYC). Fortunately, this was covered under the warranty; which I think is 90 days. Within 2 weeks, I got a brand new one.
All you have to do is convince them that it's defective and that the weather caused it to crack. Good luck...
If you have any questions, just email me.
i find that piaa has very good warranty coverage. ive never had a problem and they never question me. i had piaas on my toyota, 6months later one of the lenses were falling apart, they sent new ones
i screwed up the brackets once (my fault), they sent me new ones, no q's asked
Piaa crack, too.... thanx for all ur help~ I already return my piaa to the autorize dealer and let them send back to piaa company. I think the lens crack because of the heavy raining so it should be change under warrenty.
My PIAA craked too.. But I never change the Lens...Still works ok..However my bulbs keep blowing out every 6 months..not on the cracked one but it alternates...weird...
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
