My Personal Performance Specs on TL-S
![Post](https://acurazine.com/forums/images/icons/icon1.gif)
I have to admit -- conditions are key:
Here are the ingredients for a perfect run:
-1/4 tank of gas (less weight)
-Only one person in the TL-S (see above)
-Dry road, um, duh
-Sequential Sportshift in operation, VSC off
(VSC takes some juice away from acceleration by helping moderate the lateral movement using ABS)
-Good reaction time: at green punch it 75% until traction cntrl is over, then 100%
- 1st gear: 7000 rpms -- use that VTEC to your advantage
- 2nd gear: 6000 -- you'll find that 3rd has more of a pull by shifting slightly early
- 3rd -- use all you got here, cuz it plateaus early on in 4th!! 7000 rpm
- 4th -- well, at this point you've achieved the 60 mph spec, now you're racing for the 1/4 mile time
My personal results (sorry, I had too):
0-60mph 6.3 seconds
1/4 14.9
Not too bad
2002 TL Type S
White Diamond Pearl
Parchment
-Dry road, um, duh
0-60mph 6.3 seconds
1/4 14.9
Not too bad
2002 TL Type S
White Diamond Pearl
Parchment
-Dry road, um, duh
0-60mph 6.3 seconds
1/4 14.9
Not too bad
-Dry road, um, duh
0-60mph 6.3 seconds
1/4 14.9
Not too bad
2000 Naples Gold 3.2TL/Navi - Factory Stock but with up-graded tires
I haven't tried times with the automatic D5, but I suspect (after having revved pretty high in D5 in a semi-race) that it would be slower --
Ideally, the computer doesn't want the car to use all of the tranny's potential -- and let the engine rev too hard during a D5 full throttle acceleration. It would be excessive engine wear -- so, the caveat is, use the SS at your own peril -- just as a motorist with a manual tranny does with his car. I could be wrong, but just my take.
I didn't know that both 4th and 5th were overdrive -- actually, now that I look at the gear ratios:
(:1)
1st: 2.563
2nd: 1.551
3rd: 1.021
4th: 0.653
5th: 0.470
Fourth and fifth ARE pretty flat -- makes sense -- who'd be racing after 100?? (me!)
I let my buddy w/ the Regal GSE drive my car today -- he has driven the IS300 extensively in test drives, and he said the car is significantly quicker, but doesn't handle nearly as well -- prob. due to the front-wheel drive in some respects and the higher suspension.
2002 TL Type S
White Diamond Pearl
Parchment
(:1)
1st: 2.563
2nd: 1.551
3rd: 1.021
4th: 0.653
5th: 0.470
2002 TL Type S
White Diamond Pearl
Parchment
3rd gear in my 2000 TL takes me to 100MPH (could hold it a tad longer using SS to bump the cutoff) so it stands to reason that, in a TL-S/CL-S that has the exact same gear ratios and final drive ratio but a higher redline, you'd be able to go faster in any given gear (save for when aerodynamic drag pulls in the reins)
2000 WDP 3.2TL non-NAV
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by RAdams on March 19, 2001 @ ]</font>
A 330i manual transmission will do mid to upper 5 secs on a 0-60 quite easily. Though the 6.3 is quite comparable to an auto 330i. But considering the TL-S has more power, it ought to be faster.
In the hands of professional testers of Road and Track, with power-braking and whatnot, the 330i with manual transmission managed a 0-60 of 6.2 secs (Road and Track, January 2001).....in the hands of common folks like you and me, no way can the BMW even touch that figure....so to make un-substantiated claims like the "manual BMW easily doing 0-60 of mid 5s" and whatnot, does not sound very credible...if it is an apples-to-apples auto transmissioned BMW, I predict that the TL-s would humiliate it in acceleration....even though the BMW would edge the TL-s out in handling in bone dry weather, while the TL-s would out-handle the BMW in anything but bone-dry conditions....
just my 2c
6 speed...
![Cool](https://acurazine.com/forums/images/icons/icon6.gif)
Try racing it in full auto (D5) mode. The guys in the CL-S' prefer this over SS and actually think it's quicker. Since the cars are basically the same, the results could be too. Give it a shot!!
1998 Acura CL 3.0 (Iced Blue) ** Some mods, but who cares,
I want a Type-S... (CL or TL)!!
Moderator - 1st Gen Forum @ www.acura-cl.com
Aem Short Ram / Comptech Sway Bars / Comptech Springs / Custom Cross-Drilled Rotors / Pirelli SP7000 Tires
Alpine CVA-1005 Head Unit / Alpine G320 EQ / Alpine DVA-5205 DVD / Alpine NVE-N851A Navi / JL Audio XR653-CS 3-Way comps for the front powered by a bridged Alpine MRV-F407 amp / Boston Acoustics 5.5 ProSeries 2-Way comps for the rear powered by Alpine MRV-1002 amp / Dual 10" JL Audio W-6 sub powered by Alpine MRV-1005 amp / Two Alpine CHA-1214 CD Changers
Pics of my TL and Fun/Crazy Pics
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
