My legacy of DIY projects is coming to an end...
The UR pulley set is sitting in my trunk, and after looking around the engine bay for a while, I realized that this is a project I do not want to take on myself. First off, I don't know if the air gun will be strong enough to take it off and put back on at 187 lb/ft of torque, not to mention there's not much room to work with.
So I have decided to take it to a shop. But the problem is that I don't trust Godspeed anymore after they screwed up my car, and Payne Tech is backed up for months after their recent theft incident and all.
I don't know what to do. I want to put these on as soon as possible. Maybe I will have a tackle at it, but I don't think I will much luck with it. What do you guys think?
Those of you who have installed the pulleys themselves, how did it go? What special tools were needed?
Thanks.
Thanks.
Boomer SOONER
you said it yourself...the only real issue is the shear force that it takes to get the pulley off and new one on. I actually talked to the mechanic that installed my headers today and he said the same thing. You could do it yourself pretty easy with the proper tools (but isnt that the case with most jobs), that is why you should take it in if you dont have the means yourself.
id say go for it. you may need a pulley puller but id say go for it. start out with the crank pulley. it will be the hardest to get off. worst case senereo is you wont be able to get it off and you wll have to pay some one to do it.
if you lived a little closer id say come on over, id do it for ya
Originally Posted by Pure Adrenaline
How much would a pulley puller go for?
Also, the torque spec for the crankshaft pulley is 181 lb ft, so your impact gun should be able to handle it.
G35 Freak
What about using a nice 18" breaker bar??? That is what I used when I put the UR pulley on my G35. Just make sure that you block the wheels and have someone step on the brake when you are doing it since the car WILL move. Others have put the breaker bar against the pavement and then just cranked the motor over very slightly to break the bolt free. I wouldn't recommend it, but it will work.
Originally Posted by MikePA
They can be kinda pricey to buy especially for a one time use. NAPA shows them for a little under $100. You should be able to rent one.
your impact gun may work try it
The impact gun spins the nut off before the crankshaft can turn, right?
How's it work when tightening the nut?
Originally Posted by fsttyms1
same way. the impact gun does it by quick blows over and over, where a a breaker bar does it by constant leverage.
Did you use the impact gun to tighten the nut?
G35 Freak
I don't think there's enough room for an 18" breaker bar. It's pretty crowded in there.
cycdaniel
12-17-2019 10:58 AM
