my car is randomly locking up
My 03tlp randomly wont go from Park to Drive when I start it. This has happened a couple of times, but I can shift when I hit the release
Also, when this happens I have noticed that my radio won't turn on. I was just wondering if it this has happened to anyone and if anyone can add their
on why
thanks
on why thanks
may be the brake light switch under the pedal- easy fix- should be in the DIY
check ALL the brake lights including the ones in th eback window
or the shift interlock safety switch itself may be bad as said above
Sounds like it could also be your ignition switch because you said your radio won't turn on either. The ignition switch would trigger the shift interlock to release the shifter so if that's failing, it could very well be interfering with your radio too.
tman570
Jun 11, 2019 07:56 AM
handsom-hustla
Nov 13, 2015 05:04 PM
