My 225/55s are rubbing on me! any ideas?
I just now noticed that my new tires rub A LOT when I am making turns in reverse! (like backing out of a drive way) any ideas? I was wondering if changing the tire pressure might help out. How much PSI should I be using with these tires? I think the tires might be boldging to much during these turns, because it wont do it at very slow speeds.
Has anyone else had this problem? my car isnt dropped and it only does this when turing in reverse, its fine the rest of the time. Any suggestions would be greatly appreciated.
Dead Soul
HondaMod.com - Admin
'99 3.2TL
Black/Parchment
Dead Soul
'99 3.2TL
Black/Parchment
first, find out where its rubbing. if its the fender, get a performance shop to roll your fenders. if its the plastic trim in the wheel well, you might have to trim off some of those things. but the best solution i think is switch to 215/55 tires. changing tire pressure will not do a thing because modern radial tires changes size very little over a wide range of pressures.
it rubs more at high speed because at high speed your car generates more down force when hitting a bump, thus effectively lowers your car transiently. hope this helps.
Is your car dropped? I didn't think 225/55's rubbed? Oh, yea, don't get 215's, you made the right choice with the 225's.
"Now you see that evil will always triumph, because good is dumb." --Dark Helmet
www.distributed.net
www.distributed.net
No issues whatsoever with the 225/55-16 tires on stock TL rims. No rubbing at all. It is the best possible "mod" you can do to the car, IMO. My car is stock in every other way.
2000 Naples Gold 3.2TL/Navi - Factory Stock but with up-graded tires
If you haven't droped your car, I don't see why it's rubbing. I have CT springs and I have 225/40/18 and they only rub when I have a full car and I have to hit a dip going pretty fast. I would recommend you diagnose the problem fast cuz this don't sound right and I hate to see a fellow TL'er get screwed.
2000 TL Taffeta White
Factory Body Kit and Spoiler
18' DAZZ MATIZ
Tenzo 700X Fogs
Custom Mesh Grille
Custom Mesh Bumper Center
Comptech Headers
Comptech Springs
Comptech Sway Bars
AEM CAI
Greddy CatBack Exhaust
Inspire Tails
Inspire Steering Wheel
Burlwood Knob
Apexi V-AFC
18' DAZZ MATIZ
Tenzo 700X Fogs
Custom Mesh Grille
Comptech Headers
Comptech Springs
Comptech Sway Bars
AEM CAI
Inspire Tails
Burlwood Knob
Apexi V-AFC
Dumb question... how do you know when it's rubbing? Does smoke come out or some? Or do you hear it??
Y2K satin-silver TL, non-navi
Factory style full body kit + spoiler
Volk Racing Versus Campionato SS7 18 x 7.5 52 offset w/ Toyo Proxes FZ4 225/40/18
H&R OEM Springs
PIAA 1700x w/ Inspire Foglight switch
Polarg M-12 Front turn signals
38% window tint
Valentine 1
H&R OEM Springs
38% window tint
Valentine 1
I can hear it! If there was smoke I'd crap myself. My car isnt dropped either!
Dead Soul
'99 3.2TL
Black/Parchment
Dead Soul
'99 3.2TL
Black/Parchment
<font face="Verdana, Arial" size="2">Originally posted by hunter001:
</font>
</font>
Im running the same setup here and my tires rub when I turn to go up my drive way, but it only happends when im making very tight turns, like during parking. Its VERY common when I am backing out in reverse and I turn the wheel a good bit. I dont think there rubbing too hard, but I would like to do something. What PSI are you using in your tires? thats the only possible difference I see between our two cars.
Dead Soul
'99 3.2TL
Black/Parchment
<font face="Verdana, Arial" size="2">Originally posted by DeadSoul:
hunter001,
</font>
hunter001,
</font>
thanks hunter,
I'm gonna have to check mine out.
Dead Soul
'99 3.2TL
Black/Parchment
Dead Soul
'99 3.2TL
Black/Parchment
Guest
Posts: n/a
I had 225/17 and dropped 2.25" w/eibach springs put on my 2001 TL and here is what I did to get the rub out. I also had a offset of 42mm on my 17 wheels (std is 55mm). There is a 1" lip on the rear wheel-well, and that was trimmed so the tires would not rub the fender (works like a charm). I also had to roll the front fender (this is done manually with the strength of your own two hands, you are actually massaging the plastic liner under the wheel-well).
[img]http://photos.yahoo.com/bc/trung_m_nguyen?e&.intl=us&.flabel=fld1&.from=d&.pi ndex=2&start=1&.src=ph&.done=http%3a//photos.yahoo.com/bc/trung_m_nguyen%3fd%26.flabel=fld1%26.intl=us%26.sr c=ph[img]
07-16-2017 08:33 AM
