Moonroof Misaligned
Moonroof Misaligned
The moon roof on the right hand side is approx 1/8 inch higher compared to the left hand side. Should it be flushed with the roof? Is there an adjustement I can have the dealer do under warranty ?
Thanks for the help
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
Thanks for the help
waranty issue if its not to old
Guest
Posts: n/a
The sunroof height is adjusted by adding or removing shims located between the actual sunroof mechanism and the sunroof panel itself.Access to this can be gained by removing the trim panels on either side of the glass panel.If your car is still under warranty let the dealer do it for you as the glass panel can be easily scratched or shattered.Jens
