mirror falling apart
I know lots of people having the fluid leaking problem with the mirror...but mine is not leaking but the mirror's plastic clip/holder on the back is breaking off one by one and now it is shaking/vibrating a lot and not firmly held in place anymore. I can easily move it with a slight touch. Anyone has this problem and what is the fix for this??
seems like it just wiggled out of its position. check to make sure the pieces are cosmetic and wont affect the integrity of the mirror. if it's fine, move your car to a warm place, then gently wiggle the base of the mirror back and forth and push it towards the dome light at the same time. try to stay as parallel to the glass as you can. dont wanna do this in the cold cause well, you're cold. and your glass is even more brittle and you could crack it.
if it's causing your mirror to screw up, might wanna get a new one. it's been said that it contains mercury and other weird sheez O.o
mlody
12-04-2019 02:11 PM
ITSJESTER
17
12-06-2018 02:29 AM
soupi
14
11-15-2015 11:15 AM
