Mileage Service
Old Feb 27, 2002 | 10:45 AM
5th Gear
Mileage Service
I'm running across a dilemma whether or not I should service my car for the 30,000 mile service. It seems like all they do is check this, check that and charge you an arm and a leg. Should I just take my vehicle to other repair shops to perform the same thing and pay half the price? What's the pros and cons of having your car serviced at the dealer other than they using acura parts and overcharging you?:wow:
Old Feb 27, 2002 | 10:58 AM
TypeSDragon's Avatar
Loving my 08 TLS!
Personally, I will let the dealer do the 30K, 60K, 90K... and so on. I didn't do any of the 15K because that is just checking the fluids and such. You can do that yourself.
Old Feb 27, 2002 | 11:41 AM
99LagunaTL's Avatar
I let an independent garage do the 30K services (yes they use genuine Acura parts). The only good thing about letting the dealer do your service is that when it comes to warranty work, they might be more inclined to help you out if the service your car there regularly.
Old Feb 27, 2002 | 11:38 PM
billyvader's Avatar
Question 7500 mile service
The dealer tells me (cause my light keeps flashing) that I need a 7500 mile service. Sounds like a very expensive oil change. Am I correct? Can I shut off the light and just go get an oil change? They want $100 for this service!
Old Feb 27, 2002 | 11:57 PM
Inspire's Avatar
The New 3 Series Coupe
Re: 7500 mile service
fulla shiet! I'd say for 7500, just turn the light off yourself and do a oil change yourself...
Old Feb 28, 2002 | 07:18 AM
99LagunaTL's Avatar
Re: Re: 7500 mile service
Exactly. $100 for an oil change? Just do it yourself. As for the light, look in your owner's manual for instructions on how to reset it.
Old Feb 28, 2002 | 09:56 AM
LORD STANLEY's Avatar
Re: Mileage Service
I was reading the 30,000 mile service that Park Ave offers and I must say it sounds very comprehensive. They change all the fluids: tranny, oil, brake and coolant along with the filters. The service also checks the normal maintainence items. I'll definately get this done since it's worthwhile. I declined the 15K service because all they do is check everything and only change fluids if your having a problem with something. I generally check everything myself once a month at least to make sure it's alright.
Mike734
Dec 10, 2021 01:25 PM
08KBP_VA
Oct 22, 2019 01:55 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
thegipper
Sep 28, 2015 01:01 PM
jmaxima03
Sep 27, 2015 10:22 AM
