Meshing lower bumper
Old Aug 19, 2002 | 11:29 PM
Ok, i already bought the mesh off ebay...and now i'm going to mesh out my fog holes and the center part too.....Any tips or advice about meshing out the lower bumper? is silicon a good strong adheasive?
Old Aug 19, 2002 | 11:54 PM
digitalgm's Avatar
"v1 saved my ass ......."
why did you buy it off ebay? you can get it at your hardware store.
AdamR
Old Aug 20, 2002 | 12:42 AM
I did buy it off the hardware store, but the piece was too small. so i found a bigger piece on ebay.
Old Aug 20, 2002 | 04:33 AM
KidD WiTh 2k TL's Avatar
hey rayman . . . wassup bro . . . this is hien from the tl meet . . . IMO silicon should work fine.
Old Aug 20, 2002 | 08:39 AM
digitalgm's Avatar
Got a link to what it looks like or an actual picture?
AdamR
Old Aug 20, 2002 | 12:59 PM
Thanks, hey i was wondering can i use the same silicon for my bumper as to reseal my headlights?
Old Aug 21, 2002 | 02:59 PM
Davediego's Avatar
4dr & I like it that way
I doubt the headlight sealant would be strong enough to hold the mesh. Personally I'd reccomend quick setting epoxy to hold the mesh. Oh also, if you do a search you can find some good instructions on meshing the fog holes from Nate, but I would reccomend using a dremel to cut out the fog holes. I was using a razor blade for awhile, but after awhile I got tired/careless and it slipped and I accidently stabbed myself with the razor blade. :o Soo I got out the dremmel and finished that way, MUCH quicker then a blade.
Old Aug 21, 2002 | 10:11 PM
MadSklz32TL's Avatar
post pics wen ur done =)
Old Aug 22, 2002 | 12:13 AM
I doubt the headlight sealant would be strong enough to hold the mesh. Personally I'd reccomend quick setting epoxy to hold the mesh. Oh also, if you do a search you can find some good instructions on meshing the fog holes from Nate, but I would reccomend using a dremel to cut out the fog holes. I was using a razor blade for awhile, but after awhile I got tired/careless and it slipped and I accidently stabbed myself with the razor blade. Soo I got out the dremmel and finished that way, MUCH quicker then a blade.
what's a dremmel?
Old Aug 22, 2002 | 12:30 AM
Shyne's Avatar
its a small rotary toy...you can drill holes, cut, and shave $hit with it if you have the right heads...from wood to metal, it does its job...homedepot, ace, lowes every garage needs one...Shyne
Old Aug 22, 2002 | 12:43 AM
oooo....with all those functions comes all the $$$$....right?
Old Aug 22, 2002 | 01:02 AM
Shyne's Avatar
na at least 40 bux...and silicone is not good to hold $hit together...you need epoxy, silicone seals not bonds...Shyne
Old Aug 22, 2002 | 01:10 AM
is there another alternative for epoxy?
Old Aug 22, 2002 | 04:13 AM
Davediego's Avatar
dude just get epoxy, its cheap, and ull never have to worry about your mesh getting loose
Old Aug 22, 2002 | 01:25 PM
260hp's Avatar
Meshing lower bumper [pic]
another one
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08KBP_VA
Oct 22, 2019 01:55 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
rhdune16
Sep 28, 2015 11:31 AM
