memory seat control quesiton
there are but the pics are gone. You need to remove the screw in the door handle, and the screw behind the chrome door handle inside the car, then you push the trim piece (i believe forward) to move it out so you can unhook the handle from the metal rod. Then from the bottom of the door pull out wards to unhook the clips. then lift up on the door panel and be careful you still have to unhook the wires.
blacktsxwagon
Oct 27, 2015 10:12 PM
