mallfunction indicator lamp
Old Apr 26, 2008 | 03:21 AM
bigbluecanuck's Avatar
mallfunction indicator lamp went off tonight. I read about the gas cap. Any other ideas, or stories? I have an extended warranty.
Thx
BBC
Old Apr 26, 2008 | 08:01 AM
01tl4tl's Avatar
you mean the CEL check engine light came on?
Did you just get gas? make sure the cap is on 3 clicks minimum
5 clicks is good,,, 15 is not required~
Old Apr 26, 2008 | 09:03 AM
thisisnotdave's Avatar
Porkchop Sandwiches!
GO TO AUTOZONE!
they can check standard OBDII codes for free, so instead of headscratching, just go and get the codes run.
Old Apr 26, 2008 | 10:44 AM
Originally Posted by thisisnotdave
GO TO AUTOZONE!
No Autozone where I live. And what exactly are you saying, OBDII and codes??
Old Apr 26, 2008 | 11:18 AM
01tl4tl's Avatar
I like to start with the basics and troubleshoot based on- last thing done to the car was...
gas- check cap! as an example.
OBDI- thats the scanner that plugs into the car and it usually will give you the computer error codes the car is throwing a light for
Codes are not Diagnosis- they are CLUES to the real problem,
Most major parts stores have the scanner and will read the codes for free- then you come back here with the codes and we figure out the real problem- saving you hours and hundreds of dollars
If they dont offer that service in Canada- most Honda specialty shops or an import car repair shop will have the same tool, and for a small charge will get the codes-
and may be educated enough on your type car- to know what those codes really mean!
Old Apr 26, 2008 | 11:19 AM
01tl4tl's Avatar
Since you have an extended warranty- return to the dealer and say- I have a warning light- please fix that - and which one of these new cars is my loaner?
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
jubikej
1G RDX Problems & Fixes
Sep 30, 2015 01:13 PM
h22lude
Sep 27, 2015 06:22 PM
Eggs999bacon
Sep 24, 2015 10:08 AM
