Major fog light issue
I accidentally ripped out the foglight harness. i dont know how it happened but the bulb/ballast/harness is no where to be seen. the plastic underneath had been removed prior. i cant find any traces of the wires. this is the passenger side harness
what can i do? can i splice a wire to the other harness with a 9006 connector? if anyone can post some pics of the wires so i can trace it. itd be very helpful
ok so i spliced a wire from the drivers side to the passenger. it seemed to work fine but my turn signal started blinking rapidly and then fronts drivers side stopped working. i havent switched bulbs yet. this might just be bad luck i havent checked it out yet
i switched out the bulbs and the passenger side works find but the drivers side still blinks rapidly. atleast i have a working turn signal now. anway to stop the rapid blinking? i also noticed that since the 1157 bulb is a dual filament bub ones meant for the parking and the other is for blinker. one the drivers side only one turns on for both blinking and parking
The ballast is powered even if there isnt a bulb right? I dont remember... its been a while. Ballast for an HID bulb right? I haven't had this same issue but I recall ppl having this issue if they used LED bulbs. I believe the resolution to that is was to put a resistor in the circuit. I believe the clicking/flashing is controlled by a relay under the hood in a fuse box.
I am not familiar with this either but if it is possible, try swapping the driver side and passenger side relays to see if it still flashes fast.
Again I never tried this but it would be something I would look into to try to troubleshoot the issue.
'13 Hyundai Sonata
Go to a salvage yard, find a harness from the area you need and cut it. Then go home and splice, cut and solder, do whatever you have to do. Then tape it up and protect it however you need to and then you will have everything back to normal.
Then run your HIDs after you recieve a new set and you are back to where you started. I would also get the plastic piece that you said is missing.
GL!
GL!
GL!
GL!
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
