Maintenance Time.
Old Aug 11, 2009 | 11:11 PM
Hkshaitian's Avatar
Maintenance Time.
Well I hit 203,000 miles in my tl-s today and the maint. lights flahes when i start my car. What shoud i do pretty soon besides spark plugs and the other typical stuff?? Thanks in advance.
Old Aug 11, 2009 | 11:42 PM
TLin401's Avatar
'13 Hyundai Sonata
Give it a much needed wash.
Accessory belts, tensioners, fluids, etc.
Old Aug 11, 2009 | 11:58 PM
SLushhYYY's Avatar
Keep It Simple in
210k service is coming up, basically need to change everything you did for the 105k service.....
Blinking maintnence light is a reminder that you need an oil change, you can turn it off by holding the two buttons, select and reset, before and while turning your key 2 clicks(when all the dash lights turn on), until it goes away.
Old Aug 12, 2009 | 08:59 AM
miamirice's Avatar
Yup
oil change? i thought the maintenance needed light just means you've gone a certain # of miles (7,500??). anyway, it's only coincidence that it came on and you are approaching 210k.
Old Aug 12, 2009 | 10:00 AM
Hkshaitian's Avatar
Yea i happy it gave me the 7,000 mile heads up give me time to save and buy everything i need. Im gonna be installing a trans cooler when i do all of this.
Old Aug 12, 2009 | 10:23 AM
vdiddy210's Avatar
Sitting Fressshhh
200k is a great milestone no?
haha my TL is at 180k now, but I have an '88 civic and though the engine isn't technically from '88 ('00 SI engine) the mileage counter has rolled to about 400k now and I laugh everytime I end up taking it somewhere haha
Old Aug 12, 2009 | 10:43 AM
01tl4tl's Avatar
200 is nothing- just do the 105 and replace anything and everything that rotates
the engine is like new inside at 200,,, 300 is a reality with oil changes and proper care of cooling system
Old Aug 12, 2009 | 10:44 AM
01tl4tl's Avatar
the oil change reminder starts flashing before 7500 to give you a heads up
Thats miles since it was last reset
Old Aug 12, 2009 | 06:37 PM
Hkshaitian's Avatar
Well with 200,000+ miles, what oil would be wise for me to use?
Old Aug 13, 2009 | 08:37 AM
01tl4tl's Avatar
whatever you have been using is good to still use- this isnt the old chevy they market special oils to
Our megamoderator fsttyms1 used regular oil for 100k then synthetic another 100k- pulled the engine apart and it was like new inside
I would run seafoam everywhere, and in the oil --with a new filter installed-- to catch the amount of sludge likely in that system
As long as timing belt stays on and there is good oil pressure- these engines will go well past 300
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
LeVeL
Oct 18, 2015 04:19 PM
polish_pat
Sep 30, 2015 12:22 PM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
