maintenance required light
Old Aug 8, 2001 | 11:32 AM
Guest
Guest
Posts: n/a
First time here....wonderful site. Can't wait to get into it more.
How do I reset the maint req light?
Old Aug 8, 2001 | 11:47 AM
gohawks63's Avatar
Don't remember the specific steps. Try turning the key to the ON position and holding both the select and reset buttons.
I know it's detailed in the owner's manual
Old Aug 8, 2001 | 11:48 AM
Slammed99TL's Avatar
it's come on on me twice so far and all i do is turn the key to the second click right before you turn on the engine and hold down the reset and trip button at the same time for like ten seconds until it turns off then turn on the car then turn it off then turn it on again to see if it still comes on. it worked for me. if it doesnt for some reason look inyour manual.
hope this helps.
Old Aug 8, 2001 | 01:34 PM
Guest
Guest
Posts: n/a
the secret is not to be the key in first. So here's the steps.
hold down reset and trip button.
While holding down buttons insert key and turn to second position.
Hold down buttons until light goes off.
Interesting to note that when I put they key in first, turned to second position and then held down the buttons that the outside tempature reading went through a sequence.
It read 1, 2, 3 THEN -3, -2, 1...and then repeated.
Thanks again.
Old Aug 8, 2001 | 01:55 PM
fahoumh's Avatar
Shogun Assassin
are you sure it isn't time for service? or if you did just take it in, the mechanic probably forgot to do it himself.
Old Aug 8, 2001 | 07:06 PM
pianoman41's Avatar
Correct. Depending on what you do first, you can adjust two different things:
-Press both buttons down, turn key to II (On) position, hold for 10 seconds = reset maintenence required light
-Turn key to II (On) position, press both buttons down, hold for 10 seconds = degree adjustment for outside temp probe.
Releasing the buttons when it reads a certain number adjusts the outside temp reading by that amount. So if you held them until it scrolled to -2 and let go, your temperature reading would display 2 degrees lower than the probe measured.
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
PortlandRL
Sep 14, 2015 12:01 PM
datadr
Sep 12, 2015 09:12 PM
ahsm
Sep 9, 2015 08:35 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
