Maintenance light
Old Apr 16, 2002 | 04:03 PM
Ruski's Avatar
Maintenance light
When I turn on my TL-S, the Maintenance light flashes for 5-10 seconds and then goes away. I don't remember seeing it flash for such long time before, or am I imagining things?
Also my tranny #2 is starting to be funny again, after ~500 miles.
Stuttered again, really hard while I was cruising at 50mph. Occasionally produces rough shifts when uncalled for.
Old Apr 16, 2002 | 04:08 PM
songoku's Avatar
BlingBling INSPIRE 32V
Maintenace Require indicator is just reminder for your next service.
Simply, press & hold both SELECT & RESET button and put the key an ingnition and wait till the light goes off.
Owners manuel.
Old Apr 16, 2002 | 05:48 PM
FTM-1's Avatar
Post
Its most likely time for the oil to be changed or it was not reset at the last change. The 5 to 10 seconds flash is normal when the service mileage interval is reached.
Old Apr 17, 2002 | 09:20 AM
DallasTypeS's Avatar
i held the buttons down for 10 seconds with the car running...seems to allow you to adjust the outside temp gauge by 3 degrees up or down... may be in the manual, don't know.
Old Apr 17, 2002 | 10:12 AM
Its in the manual, I think the key had to be in position II and you had to hold both buttons before turning the key to that position.... anyway its in the manual.
Old Apr 17, 2002 | 11:26 AM
songoku's Avatar
Please remember that you have to press & hold 2 buttons BEFORE you put the key in ignition. If you press & hold the buttons AFTER ignition, it will go to temperature setting.
PRESS & HOLD THE BUTTONS BEFORE PUT THE KEY AN IGNITION!!!
mada51589
Jan 9, 2025 04:40 PM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
EE4Life
Sep 11, 2015 10:09 PM
ahsm
Sep 9, 2015 08:35 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
