maintance light
maintance light
the maintance light is on for some reason. it just stays on and i dont know what to do. i just had an oil change but it wasnt from the dealer.please tell me how i can turn the light off.
2002 acura 3.2tl type s
wdp
wdp
As stated in the manual, hold down the trip odometer "Reset" and "Select" buttons. While holding them down, turn the ignition key to the II position (the one right before the engine cranks) for 10 seconds. Then release the buttons and shut the ignition off. This will reset your maintenance required light.
Make sure you hold down the "Reset" and "Select" buttons *before* turning the key. If you do it after, you will enter the mode for adjusting the offset for the outside temperature probe, which allows you to compensate +/- 3 degrees for calibration issues. If you don't know what it was set at to begin with, you could mess it up and have to reset it by trial and error.
I was able to get my maintenance light off, but now my car is making a beeping noise. It gives off two low beeps, waits about 15 seconds and repeats. This is driving me crazy. Any ideas on how to turn off the beeping? I screwed up the first time I tried to turn off the maintenance light
mada51589
05-03-2022 08:54 PM
sockr1
10-01-2015 01:31 AM
wusty23jd
09-24-2015 11:41 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
