magnetic oil drain plugs
Of course. It'll keep all the metal shavings, if any from circulating back through your engine. The sump filter usually won't block all of the tiny stuff.
I got `stick like` magnets at harbor freight- $1 each, and slap 2 on the outside of the oil filter
They are made to be used inside the filter but are too long for the TL
Everything you can do will help- including run a cleaner like seafoam thru the oil before change- the sludge on tv is real~
B A N N E D
x2
but now if you had some serious issues with your engine, they might help, but the best thing you can do for your engine is change your oil every 3,000 miles and put in quality oil (valvoline, castrol, etc) with a quality filter (especially one that has a antidrain back valve in it, so it builds pressure faster)
for the average driver- the TL is set up to go 7500 between changes, thats why the oil minder is set for 7500,,starting at about 6500 till you reset it
Extreme temps or driving style, lots of short trips.. do merit changing sooner
get an oil analysis done and see what you can be doing for oil life and exactly what metal bits are in the oil- all parts wear and certain amounts are expected- while others indicate trouble in the works
Its my opinion that car makers and oil makers are in colusion and the standard is set at 7500-so oil is made to last 8000 then certain needed additives wear out
B A N N E D
Oh please. 3k is way to often and a waste of money. My car would idle all day with tons of fast stop and go. If that wasnt severe i dont know what was. i went 8k on average (with regular oil) and the oil life was fine (had oil tested)
B A N N E D
![](http://img94.imageshack.us/img94/7452/oilfill.jpg)
![](http://img94.imageshack.us/img94/3121/oilfill1.jpg)
btw : that was the first time the valve covers have been off since new/built over 6 years ago
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
then why did my engine not have the brown tint (looked brand new with oil just on it) on the front bank when i just adjusted the valves at 104k (pictures through oil fill); back had some brown tint due to running hotter being at the back of the engine compartment![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
and i am not taking them off again just for pictures
in reality- the engine oil has a nice big filter thats replaced every time, so it should be catching all the metal particles
the trans uses a magnetic plug because it doesnt have the same type filter system, so a magnet holds whatever comes past it instead
on the old chevy truck filter it fits inside like the pic, so thats where I ran it with no issues
The TL filter is shorter than the magnet and wont fit inside fully without snapping in half--which is easy to do but leaves a rough edge--does breaking it affect the magnet?- I dont know-
So they now go on the outside of the filter at full length
No problem with falling off- also use them on the bike (which happens to use a TL filter)
and gets a lot more road debris damage potential and bumps trying to throw it off
In theory they should be working thru the can- at least we can feel that we are going the extra step
Just like you dont need synthetic oil but it makes you feel better
B A N N E D
but the funny thing is there are alot non-ferrios (exp. aluminuim ) metals in engines now a days, so maybe not as effective now, then back in the day, (crankshaft, rods, oil pump, cams, rockers ,springs, etc., etc. are still ferrious though)
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Traded in my
Hmm..I'm liking this magnet idea for the tranny filter. Help that little plug magnet out some cuz I can't imagine such a small magnetic area is catching everything. Thanks for the idea guys!!
yes you can do that too, but you want the stuff to drain out so remove it before oil change
A filter of any decent quality- meaning more than a roll of toilet paper in a can-
is catching the particles--or acura would use a magnetic drain plug
There is still wear on parts that will be attracted to a magnet- and if its captured in the can to its inner edge- thats cool by me
My concern on using a broken-to-fit magnet was adding micro particles from its rough edge into the system- creating a problem where none existed
people were throwing out alternatives if you want a mag plug and cant find one
I believe its better to use something on the filter rather than trapping crud in the oil pan where the pickup tube assembly is located,,of course this is extra protectoin- not really an issue, but for the type of person that likes to safety wire..
B A N N E D
anyways what do you attach the other end to???
B A N N E D
and now you can get some veteran license plates if kentucky gots any
but for 01tl4tl it kinda sounds like he only does it on his car or something,
where you did it day in and day out for 6 or more months at a time, so yeah you get tired of it real fast,
anyways thanks for serving
2000 acura tl FPR
but needed on something like an aircraft where you can't just pull over to the side of the road like a car
and now you can get some veteran license plates if kentucky gots any![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
anyways thanks for serving![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
kentucky has veteran's license plates, but they also had active duty license plates too, but i didn't want to drive around hampton roads virginia (everyone hates people in the military there) with plates that said i was who i was.
i'm sure 01tl4tl was just kidding about safety wiring the oil plug.
I was kidding and meant in general --- the type of person who would safety wire everything,, also runs a magnet of some kind~
Its trick but not needed
I do own 3 sets of safety wire pliers and have worked on many race cars and aircraft where the oil filter loosening is a real issue, or loss of oil plug is disasterous
Now I do it just to freak out the neighbors,,wear a white lab coat working under the hood- stethascope etc lol
IBankMouse
06-13-2020 12:53 PM
xsilverhawkx
09-28-2015 06:51 PM
STL TL-S
09-23-2015 08:52 PM
