Lug nut Torque
Old Apr 9, 2004 | 09:10 AM
csilano's Avatar
Just enjoying the ride!
Lug nut Torque
What is the proper ft lbs to torque the lug nuts on the factory rims on an 03 tlp.
Old Apr 9, 2004 | 09:13 AM
Dare_IL's Avatar
Need a WHAmbulance
80 lbs should do it. :think:
Old Apr 9, 2004 | 09:17 AM
csilano's Avatar
Old Apr 9, 2004 | 12:18 PM
drcookie's Avatar
I set mine to 100 Ibs.
Old Apr 9, 2004 | 12:53 PM
edgalang's Avatar
Purchased: April 28, 2001
:cop: Manual says 80
Old Apr 9, 2004 | 08:15 PM
FLAcuraTLS's Avatar
believe it or not, torqueing your lugs that high can do damage to not only your rims, lugs, and wheel studs, but you can do damage to your brake system..you'll be warping your rotors much quicker due to over torqueing and who knows what else could go wrong....i would go right now and re-torque them to 80 ft/lbs
Old Apr 9, 2004 | 09:29 PM
goldendragon576's Avatar
TL-S driver
80 for stock wheels but 100 for aftermarket. The fitting is different between the stocks and the aftermarket. That's what I was told by my tire guy and tire rack.
Old Apr 9, 2004 | 10:43 PM
njtls's Avatar
ive been taught 100 for aluminum rims and 80 for steel..so thats what i stick with
Old Apr 10, 2004 | 08:55 PM
NSX4dr's Avatar
Original Member #81
It doesn't matter what wheels you have on your car. When you torque the lugs it streches the stud. The torque is different on different cars because of the tensile strength of the stud used.....
Therefore it's 80ftlbs regardless of the wheel choice........
Charles
Old Apr 10, 2004 | 09:05 PM
njtls's Avatar
Charles
well now that ive been torqueing my wheels at 100 and my studs are stretched..is it safe to go back to 80?
neuronbob
23
Jul 16, 2019 10:48 AM
knight rider
Mar 4, 2016 08:59 AM
Skirmich
Oct 1, 2015 12:59 PM
hpfiend
Sep 27, 2015 06:59 AM
MilanoRedDashR
Sep 24, 2015 11:04 PM
