lowering question
Shogun Assassin
lowering question
I was told that when you lower your car you sacrifice some of the quietness characteristic of our cars. But I'm not sure how this works....I'm not doubting them, but I need an explanation of how this happens. And what kind of noise is created? If anyone could help me out, it would be great. Thanks!
Retired MOD
1 Post
Re: lowering question
For example less air travels under the car if lower. Does that create noise
as far as air flow goes... I don't think that's gonna be the cause or at least not gonna create an noticable difference in normal driving...
but it does create the following effects...
1. depends on your spring/coilver, your car can be a lot STIFFER, and that will cause more rattle, nosie cuz it's bumpier...
2. if your spring/shock is not installed correctly, then they may create some noise, too...
Being closer to the ground, your car has less frontal aera.... which should compensate any extra noise caused by the underbody if any!!! So, wind noise shouldn't be a problem..
DiamondJoeQuimby
09-10-2015 11:40 AM
