Lowered and headlight too low
After i lowered my tl about 2.1 front and 1.75 back, now seems that the headlights are low. I saw once on the forum that one person said the headlight can be adjusted by a phillip screw driver. Can anyone identify where exactly the place for adjustments? Pictures would be great. Thx in advance.
In addition, what should be the correct height of the headlight or how i can measure the height of the light?
i
On the back of your lights, there should be a 10mm bolt between the HID and Highbeam light bulbs that you can turn, clockwise to lower the light, counterclockwise to raise it. The bolts have a blue mark on my car.
Don't have any pics but its pretty easy to spot the bolt. I believe it's 10mm. If you cant c it, try removing the plastic radiator cover.
you will need a 10mm, and a 5/32 hex. you will see U & D (up/down) and L&R (left/right) behind each headlight, look the on plastic trip on top for the leterring, then look right on the back side of the headlights, and you will see round metal knobs.
do the aiming against a wall about 25 feet back for best results. peace.
Mr. 2tone
so 25 ft bak...but where should they stop hitting the road...kuz i adjusted mine the other nite...parked in front of a wall like 5ft then i just leveled the beam directly across to where its even height
well, u r aiming the 'hot spots', and they should be a few inches (1.5-2.5 inches) lower than the distance of ground to your headlights, otherwise you will be blinding others drivers guaranteed. but 25 ft back you can tell where the light is hitting (hot spots).
Mr. 2tone
take a ruler, measure the distance from the ground to the middle of your headlight....now take that measurement to the wall, subtract like 2 inches from the measurment, and mark the wall with that new measurement, and align your hot spot to that.
NiGhT rIdEr
im kinda screwed cause my right headlight points almost straight down and the aiming knobs arent working...i called acura and they said they charge about 45 to aim them, but i know theyre gunna tell me i need a new housing
plaza auto mall is an official STEALERship!
yeah, thats a number 1 stealership. I hate that place, especially Marcus, and Katie is the dumbest woman on earth.
What happend to yer knobs? Also, maybe you can somehow point the bulb itself a tiny bit upward?
Originally Posted by z3Ro
i did not get the 1st part of u were talking bout at all...the inches part...lol...
NiGhT rIdEr
BTW...marcus is a dick and ur right when u say katie is dumb...but some of the girls that give u the receipts are pretty hot lol
i have located the the 10mm bolt. only problem for me is that there are not enough space for the socket. i guess i have to do some clearance before i can do the adjustment. also i think i need to take out the top plastic cover first.
Need a WHAmbulance
You don't have to use a 10mm socket. You can also use a 4" long or longer Phillips screwdriver. Just make sure it is a pretty good size diameter screwdriver. About the size of a pencil or a little bigger works fine. There is a place made along side of the adjustment cap just for this. The teeth of the screwdriver slide inbetween the teeth of the adjustment cap.
1fatcrxnem1
22
06-01-2018 01:23 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
