lower control arm quick question
Old Jun 19, 2008 | 09:54 AM
chrismeoli's Avatar
i replace my drivers side lower control arm yesterday because the bushings were gone, paid 70$ for a new one with bushings from macautoparts.com, if you need one but my question is how tight, what tourque the arm should be at the mount to the car. It is on there tight and needs some good pressure to swing up and down now, is this about right? the old one just flopped to the ground when everything else was unbolted. thanks guys!
Old Jun 19, 2008 | 11:16 AM
fsttyms1's Avatar
47 ft/lb
Old Jun 19, 2008 | 12:09 PM
chrismeoli's Avatar
thanks! so it should have some movement or drop on its own then? its weird, it sounds like i have a noise coming from the other side of the car now, i did the drivers side and afterward the passenger is clunking a little? i will never figure these cars out!
Old Jun 19, 2008 | 12:12 PM
fsttyms1's Avatar
Have you checked the sway bar endlinks?
Our cars are starting to get up there in age and miles. A LOT of these parts are really needing to be replaced and in many cases (like myself) should have been done years ago. Technically most of our suspension components with rubber bushings should be replaced every few years to keep things tight.
Old Jun 19, 2008 | 12:49 PM
chrismeoli's Avatar
i did just do those about a month ago but i notice the drivers side endlinks move very freely already, i noticed this when i disconnected it from the lower control arm, it still shoul dbe kind of tight i would think?
Old Jun 19, 2008 | 01:26 PM
fsttyms1's Avatar
Should be fairly tight. Was there tension on the sway or were the control arms hanging (car jacked up?) if the later test tehm with the car sitting at ride height.
Old Jun 20, 2008 | 09:43 AM
chrismeoli's Avatar
no , good idea, i just checked the endlinks while they were off the car. gave them a quick feel and they moved around pretty easy.
marcelft
Jul 10, 2018 06:17 PM
KB1_EJ6
Aug 28, 2016 08:25 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
gqdabien
Sep 8, 2015 11:41 PM
nuldabz
Sep 3, 2015 05:49 PM
