Lower Ball Joints
Old Jul 12, 2012 | 02:15 AM
Karanx7's Avatar
Unregistered Member
Lower Ball Joints
Hey guys, I need to replace both my front lower ball joints. Got a few Q's:
1) I read from the 3G side, the sleeve in the LCA can come out when removing the LBJ from the LCA. If this happens, you must replace the entire LCA =[. Is this issue present on the 2G TL too?
2) I also read from the 3G side, the nut is too small to cover the sleeve inside the LCA completely. This causes the sleeve to just pop out of the LCA. Again, is this an issue for the 2G part?
3) What is the part number for the ball joint that you recommend?
Old Jul 12, 2012 | 08:45 AM
fsttyms1's Avatar
For starters, you have a 2g. quit reading the 3g stuff
Im not sure what they are talking about, but there is no sleeve on the 2g.
Old Jul 12, 2012 | 02:15 PM
Karanx7's Avatar
Unregistered Member
That's awesome, less worries for me.
I know you had to replace your LBJ once, but said that they only sold it with the knuckle. After that, I think they released a kit for just the LBJ. I couldn't find it on any website diagrams, do you know where I could find it? Or should I just get Moog ones?
Old Jul 12, 2012 | 02:40 PM
Stephen00TL's Avatar
Chapter Leader (Southeast Region)
Did you check rockauto.com? I was looking ther yesterday and they had a lot
Old Jul 12, 2012 | 03:22 PM
Skirmich's Avatar
Just buy the MOOG LBJ and Call it a Day... Being Riding with it for almost 6 months with no Problems at All...
Old Jul 12, 2012 | 03:42 PM
victus1's Avatar
Are the moog better or longer lasting than the OEM ones?
I am thinking of doing mine as well.
Old Jul 12, 2012 | 06:23 PM
The attached file shows a Service Bulletin from June 06 that is in regards to Lower Ball Joints. However, it is old and I don't know if it is relevent these days with all the aftermarket LBJ's available for 2G TL/CL's.
File Type: pdf
Old Jul 12, 2012 | 08:42 PM
fsttyms1's Avatar
Moog and call it a day
Old Jul 14, 2012 | 09:42 PM
3.2TLc's Avatar
lower BJ
Yeah, the Moog's are top quality and have grease fittings to boot. I'd replaced both sides @ 105k and now have 160k, three years later with no problems !
Old Jul 15, 2012 | 12:46 AM
Is everyone getting just the regular one or the one where you can adjust it?
Old Jul 16, 2012 | 08:49 PM
Skirmich's Avatar
Ive got the one that you can Adjust for the Price of the Normal one @ Autopartswarehouse.com
FYI Left is LBJ and Right UBJ:
Old Jul 16, 2012 | 09:53 PM
xi0utlawstarix's Avatar
8th Gear
How about getting an oem balljoint from 97 accord??...$20 part# 51220-S84-A02.
Moog K9643
ACURA
CL 2003-1997
TL 2003-1999
HONDA
ACCORD 2002-1990
ODYSSEY 1998-1995
ISUZU OASIS 1999-1996
Old Jul 17, 2012 | 02:35 AM
sl33kTL's Avatar
+1 on moog. Running MOOG LBJ, links, and tie rods. All better than oem IMO along with ingall camBer kits.
Moog ftw
Old Jul 5, 2013 | 11:32 AM
paperboy42190's Avatar
That is a problem ONLY with the moog ball joint, and its easily solved by adding a slightly bigger washer or a bigger nut. https://acurazine.com/forums/showthread.php?p=12706350
Old Jul 5, 2013 | 01:10 PM
3.2TLc's Avatar
Anybody else with our 2nd Gens experience this problem with the Moog replacement BJ ???
The reason that I ask...is that Moog BJ's were used on my 2000 TL and I don't recall any problems with installation or "popping" out. It's been 2 years and 15k since replacing originals...!
Old Jul 5, 2013 | 01:11 PM
Karanx7's Avatar
Unregistered Member
^Yea, I only made the thread because I was worried about that problem.
Since the 2G cars don't have that poorly designed sleeve that pops out, the Moog part works well for us.
Old Jul 5, 2013 | 01:29 PM
Damn lucky 2G.... Anyone wanna trade cars?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08KBP_VA
Oct 22, 2019 01:55 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
rhdune16
Sep 28, 2015 11:31 AM
