Low Beam Questions
Old Sep 26, 2013 | 04:18 PM
Jason_TL-S's Avatar
7th Gear
Low Beam Questions
Hello, I've seen all the threads for low beam headlight issues. I took the bumper off and replaced the ballast, igniter, and bulb on the bad side and it still wasn't functioning. I took the car to a cert. Acura service place and they said it was the headlight fuse relay which they replaced. It worked for a couple of hours and finally kind of sizzled and won't come on any longer. My other side now only comes on for a couple of minutes and shuts off. I have to turn off the lights and cut them back on for it to work before it shuts off again.
I got the parts from an ebay store, are they reliable? The dealer says the part was used, the store claims it was new. Is it normal for both inverters to go bad at the same time because it was fine until it went to the shop? I'm in Colorado so maybe all the rain we got managed to get into my headlight's? Any suggestions?
I just spent thousands on the car to get it up to speed and can't even wrap my head around spending an additional $1500 on headlights.
Old Sep 26, 2013 | 11:55 PM
Skirmich's Avatar
Wait what? Why did you spend money on the original ballast?
DUDE! You should use Aftermarket kits when the OEM Ballast go out and retrofit it! It cost around 50 bucks (A good set with Warranty) and the installation is straight over...
Get this:
Amazon.com: d2s d2r HID Xenon AMP Aftermarket Ballast Adapter Plug Base (Pair): Automotive Amazon.com: d2s d2r HID Xenon AMP Aftermarket Ballast Adapter Plug Base (Pair): Automotive
and 2 of these:
Amazon.com: Zenex 35W AC Universal Replacement HID Digital Ballast: Automotive Amazon.com: Zenex 35W AC Universal Replacement HID Digital Ballast: Automotive
Make some cable wiring and DONE! Aftermarket kit for 50 Bucks!
BUT! You should check out why your fuses are blowing! Even with aftermarket kit if you got something wrong in your electrical system they will also fail!
Old Sep 27, 2013 | 07:23 AM
3.2TLc's Avatar
Yeah, as Skirmich said. Get the newer aftermarket HID kits to replace your original low beams. Could be the wiring connections are corroded or perhaps there's a poor ground causing issues. Check the "DIY"s and other threads again for more info on troubleshooting and replacement.
Old Oct 7, 2013 | 04:07 PM
Jason_TL-S's Avatar
7th Gear
Thanks, problem solved
Old Oct 7, 2013 | 05:05 PM
3.2TLc's Avatar
So, was it something simply overlooked or did ya get a new aftermarket HID kit ?
Old Oct 21, 2013 | 06:04 PM
dante76's Avatar
Would you happen to have any detailed instructions on how to get to the ballast? I have to change mine now.
Thanks!
Old Oct 21, 2013 | 06:48 PM
Skirmich's Avatar
^^ Remove bumper... Remove headlight = Vuala!
There are 2 bolts on each side of the bumper..
You have to remove all plastic clips from inner front grille holding the grille into the chassis
Remove plastic pins holding the mud guards into the front bumper.
Once the bumper is out there are 2 top bolts holding the headlight and 1/2? on the sides (Thus having to remove bumper).
Old Oct 21, 2013 | 09:33 PM
AlanW's Avatar
2006 NBP TL MT6/ 02TL-S
I just installed a HIDextra 5000K kit that cost $59.00 delivered (with discount code). The kit included everything including all wiring and was plug & play, just splice in 2 wires on each side for the power.
Old Oct 26, 2013 | 06:12 PM
dante76's Avatar
Get this:
and 2 of these:
Will this kit require one of those 9006 adapters? i don't see how the ballast can be powered without using the adapter and splicing it into the OEM wires.
Old Oct 27, 2013 | 05:54 AM
HairyMonkey019's Avatar
Why would we need 9006 adapters if our headlight low beams are D2R's???
And 02-03 headlights have 5 bolts holding the headlight in place. 2 on top, 2 underneath, and 1 where the bumper and fender meet. The 3 bolts underneath and next to the meeting point of the bumper and fender are holding a metal frame, along with the headlights.
Old Oct 27, 2013 | 01:23 PM
dante76's Avatar
It was my understanding that an adapter is needed because the ballast itself has a female input (9006) for the power. If we remove our oem ballast we would need to splice it to provide power to the new ballast, correct?
Now if the ballast doesn't have the wires and uses a 9006 input u must get the 9006 adapter and splice the end and connect it the end that was cut, correct.
If I'm mistaken please guide me to learn how to power an aftermarket ballast if most are conversion kits . I've not been able to find any type of direct plug. And play type ballasts
Old Oct 27, 2013 | 02:58 PM
You are actually correct. Let's say you go to ddmtuning.com like I did.
You enter everything you need. When you put D2R as your bulbs they will provide that adapter but of course costs little extra.The adapter plugs straight into the ballast and is required to be spliced into the OEM wire harness.
Old Oct 28, 2013 | 03:01 PM
dante76's Avatar
great...ok just needed to be sure...need to order for my wifes cl...she's been riding around with one headlight for nearly 3 weeks...lol
Old Nov 1, 2013 | 12:36 PM
MrBowles's Avatar
I had a similar problem. Have you checked the grounds and terminals? I replaced mine last week and so far my lights have been fine. I would check for corrosion on or around the negative terminal then look for oxidation in the ground wires
AndrewS
19
Mar 14, 2024 06:59 PM
TLDude876
Dec 28, 2016 03:18 PM
datadr
Sep 12, 2015 09:12 PM
phillyguerrilla
Sep 11, 2015 06:39 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
