loss of trany fluid
Old Apr 16, 2008 | 01:08 PM
Toronto_99_3.2tl's Avatar
loss of trany fluid
hi guys... i had a new tranny put in about a yr ago by acura. just recently i noticed harsher than normal gear shift so i checked the transmission fluid and it was a little low. i dumped a bottle of fluid in that i got from acura and it seemed to fix the problem. now it seems to be shifting harsh again. should this be expected? should i have to top up the tranny fluid about once a month or every 2 months? seems a little abnormal to me. mind you car does have 280 000km on it.
any suggestions or thoughts would be appreciated..
Old Apr 16, 2008 | 01:12 PM
01tl4tl's Avatar
sounds like a seal has failed- you should not have to top it off- pretty much ever~
Since you had acura do the trans a year ago, stop by there and speak with the service manager.
If you can look underneath and see if its coming from the axle or from the area where the engine and trans meet- that helps diagnose the problem
Old Apr 16, 2008 | 01:13 PM
fsttyms1's Avatar
The trans shouldnt be using any fluid. I would start looking for a leak. (i also would have brought it up with acura about it. if there was a problem it may have been covered?)
Old Apr 17, 2008 | 11:12 AM
i just discovered this recently, but i will indeed look for a leak today...and should i find something.. i will take it back to them... thanx
Old Apr 20, 2008 | 11:07 AM
mzahidi's Avatar
similar issue
my transmission has gotta bit rough, so i checked my fluids today, engine good fluid good, tranmission , LOW
any ideas
i'll top it off and lets see
mzahidi's Avatar
transmission was changed about 2 years ago
Old Apr 20, 2008 | 01:57 PM
01tl4tl's Avatar
drive 15 minutes on freeway cruising to warm trans- stop- put in park and shut engine OFF
remove trans dipstick and wipe- insert fully- remove and read
Should be between the dots
Other temp reading will be way off
SidhuSaaB
May 30, 2020 12:40 AM
Pham Alvan
Mar 16, 2016 09:17 AM
LeVeL
Oct 18, 2015 04:19 PM
Rcelestino93
Sep 23, 2015 10:01 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
