"loose" steering... suggestions?
My 02 type S's steering just doesnt feel tight and crisp anymore like it used to. It feels like it has a little extra play in the steering wheel. I was told that my drivers side upper ball joint had excess play and needed replacing.... would this make the STEERING loose?
If not, what parts of the suspension, bushings, etc should I check? I have springs, shocks, sways already.
Im going to replace the balljoint first. I have been toying with the idea of replacing lower control arms and various bushings, but wasnt' sure which ones I should go with (assuming I don't find wear on mine). I'm at almost 150k by the way
Get that replaced right away. If that fails, your wheels fall off...
And check the tie rods ends also. They control steering and have a ball joint similar to the upper ball joint.
I have one upper (spc camber correcting ball joint) gone bad....... so I should replace the lower too? Maybe even replace the other side upper and lower? Sounds pricey, but I'll do it if you think I will notice a difference. The lowers ARE 150k old
if the upper on one side is bad its been putting extra load on its lower, so replace both
Mostly its the labor getting to the part, the cheap bit is the extra part~
A good shop would stop and ask- why dont you want the other one done??
If the other side is ok dont worry about them till one gets worn- monitor at oil changes--look all the suspension over
lowered cars put more wear on those type parts in general
The TL will go well past 300 if you maintain it when it needs- see fsttyms1 threads on his hyper high mileage 00, now with cl-s/6speed!
what if a mechanic [or two] actually got under there, looked around, pushed, pulled, turned and twisted some suspension parts around, but said that the tie rods, and balljoints are still good... is there a chance that its actually bad, just not easily seen? something they missed?
ive got the clunking issue on my tein basics... as theres been numerous threads on this topic. but im just curious if mayb they cant tell the balljoint is bad by playing with it... just something you have to change without it looking bad...?
4drviper
Apr 23, 2025 07:13 PM
kb1rl
Sep 30, 2015 10:17 AM
