Loose front suspension, Ball Joints?
Old 02-09-2006 | 01:56 PM
fred3113's Avatar
Exclamation Loose front suspension, Ball Joints?
Lately when i drive my car over a rough road it almost feels like my front suspension is loose and makes some wierd noises like squeeks almost, i have about 131,000 miles on my 2000 acura tl, Do you guys think it's from the ball joints?
How easy are those to change?
Is there instructions anywhere?
thanx guys.
Old 02-09-2006 | 02:36 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
I've always wondered about this. I've driven a couple of high mileage cars and felt that, and in one replacing struts didn't help. Sigh..age..
Old 02-09-2006 | 03:20 PM
ACURATECHTX's Avatar
i would suspect the front struts first then the joints last
Old 02-09-2006 | 03:28 PM
Lazy_E's Avatar
Its the ball joints, I just had this problem. Squeeking over bumps. At first, I also thought it was my front suspension (Koni Yellows) but I got it checked and it is the ball joints.
Old 02-09-2006 | 04:19 PM
LeftCorner's Avatar
SH-AWD
Only way to get the balljoints is to replace the complete knuckle. When you do that you also need a new wheel bearing. Parts are around $500 for one side.
Old 02-09-2006 | 06:32 PM
miamirice's Avatar
Yup
Woah...I have this same problem now (the squeaking) and my mechanic just quoted $170 for the ball joint. He didn't mention anything about the knuckle....
I hope I don't need $500.
Old 02-09-2006 | 06:53 PM
fred3113's Avatar
come on
ok, now i know they would not design the car where you would have to replace the entire knuckle to get the ball joints, thats just bad design. You have to be able to get to the ball joints, i will check it out this weekend, and do some more research on this topic.
Old 02-09-2006 | 07:10 PM
MotionEffects's Avatar
Acura TLS are SLOW
If you go through your dealer, they will replace the whole knuckle. But at a local mechanic shop, they will replace just a ball joint.
Old 02-09-2006 | 10:05 PM
Elegant TYPE S's Avatar
Being an Acha Bacha in
Yes Just had it done at Sears, they charge $56 for the ball joint made by "MOOG" seems to be the best brand for ball joint according to a few shops, and the labor was $70. So about $130 in all for one side to be replaced.
Old 03-07-2006 | 11:19 AM
case80's Avatar
I have the same problem and Acura just quoted me 800$ for this. Has anybody had any long running success with local ball joints? I have the problem on both sides, but I'm only replacing the driver side today. I'll do a local mechanic for the passenger side if it apepars to be successfull.
Old 03-07-2006 | 02:50 PM
kuzdu's Avatar
Styl1n
moog is gooood stuff
jblessing
08-08-2018 09:43 PM
marcelft
07-10-2018 06:17 PM
Heyzuez20
10-14-2015 07:18 AM
jblessing
Wash & Wax
09-17-2015 09:28 PM
08 NBP TL
09-08-2015 08:49 PM
Quick Reply: Loose front suspension, Ball Joints?
