Long trip made car faster......
Young Fresh 2 Def
![Wink](https://acurazine.com/forums/images/icons/icon12.gif)
This passed weekend I went down to my school, Universty of Maryland Eastern Shore, to graduate
. The trip takes about 4 hrs one way. Once i got down there I got an oil change with Mobil 1 at a local shop. On the way back sunday night everything was normal, once moday came and it was time to go to work I shit u not my car felt like i had about 40 lbs more tq down low. Today is wednesday and the car stills feels like this. On the down side the car is running much hotter, the themostat needle alomost reached the H. Can anyone explane this. BTW i have an appointment with acura this friday to see why it running hot.
Thanx in advance for any responses
![Yes](https://acurazine.com/forums/images/smilies/yes.gif)
How many miles does it have on it? I've read the more miles on the engine the better its broken in and gas mileage and performance improve with the miles.
Could be that? Just a guess though
have you checked your radiator fluid level?
when i brought my toyota to the dealer for the 15k service check, they did not tighten the radiator cap correctly...almost all of the radiator fluid leaked out. the car was running hot. found this out when i checked the radiator fluid level when the engine was cool. i replaced the fluid asap.
Whatever you do, dont run that engine with the needle at the H mark. If needed, call the dealer and have em tow the car in.
Cars like this with Aluminum heads will warp, and blow the head gasket in no time flat.
I second that!
02 TL-s WDP
BUt if your taking it to the dealership ...i think they'ld have the common sense to check that.
Young Fresh 2 Def
Thanx for the imput
the radiator fluid looked a little low when i checked it but on friday when i take it in to acura they should tell me if there is anything else wrong
fyi...i bought the car and have the car serviced at the same dealership. no one else has touch anything under the hood.
