Locking the doors with the engine running
I Like Pie
Does anyone know if it is possible to lock the doors on a TL after you have started the engine? I'd like to be able to go out and start the car in the morning, and lock the doors to keep it secure while it warms up and I go inside, then just use another key to unlock it again to drive.
Is there a way to override the "no lockout with key in ignition" feature?
2000 acura tl FPR
yes. basically, my way around it is to start the car, close the door, and use your OTHER key to lock your already closed door. bada bing.
keep in mind though, this is the ghetto warm up procedure, if someone really wants your car, all they would have to do is break the window and the engine is already started for them, they can just drive off. so i'd be careful as to what neighborhoods you do this in. if you really cared about security, get remote start
warming the car for more than a minute is counter to what it needs to get warm--movement across the ground
-see owner book
by the time the gps is up- seatbelt on, seat heater on,,the car is ready to get moving.
If it will rev to 2000 its good to go
Keep rpm under 3000 until some temp reading (a few blocks driving)
seat heat note:
start on High until butt and back warms to satisfaction, then switch to LOW and leave there.
High will run until temp hits an `over-limit` switch and shuts down- when cools below certain point it switches itself back on
This constant heat contributes to the broken butt seat heat wire --about where a wallet in back pocket would place extra stress on seat~
on LOW it runs until a lower heat limit and shuts off- turns back on when a few degree drop occurs--so it works like a thermostat keeping you toasty not roasted!
-see owner book
seat heat note:
I Like Pie
thanks for the info guys.
assclown - can you use the other clicker to lock the doors or do you need to actually insert the key and turn it?
01tl4tl - yea i knew that i just wanted to know because winter is approaching, and frost is prevalent on the windshield in the morning. Rather than sit in the car while it defrosts i like to finish getting ready for work. I always like to let the engine oil get flowing and warm and such before putting it in gear anyways - helps engines last longer IMO.
My butt seat htr. element burned open where there is a metal rod that holds the seat cover down. That rod presses on the element & stresses it. Also saw burnt in same place in pics of other members seats. For more info & pics: https://acurazine.com/forums/showthr...hlight=element
I Like Pie
makes sense. I you have the key to lock the door, you obviously have a key to unlock it as well, and thus are not locked out.
Damn car is smart
Damn car is smart
2000 acura tl FPR
and tom, call me lazy haha, but i don't like to scrape ice and crap off my car, so i like to let it warm with the defroster on 90 and by the time i'm ready, i'll have clear windows without touching a thing.
i won't be driving my car in the snow though this year so no worries.
I Like Pie
now why would they do that? That defeats the purpose of the system. The Acura designers have obviously never owned a dog or child that could press down on a door lock button...
If you pull the drivers side inside door handle like you are trying to open the door and push the lock button to lock the doors then let go and close the doors it won't unlock them.
This!
Open passenger door
lean over to ignition
insert key
turn on
lock doors from passenger side
close doors...
then..
spot spare key on same key ring as the key in ignition
call AAA
forgot your membership expired
pay an arm and a leg
doors open
drive to work
arrive 1 hour late
Open passenger door
insert key
turn on
close doors...
then..
call AAA
doors open
drive to work
arrive 1 hour late
rockyboy
08-04-2024 10:35 AM
tman570
06-11-2019 07:56 AM
ahsm
09-09-2015 08:35 AM
