Legend calipers
Old Apr 3, 2008 | 09:32 AM
vip_inspire's Avatar
is making xxx movies
Legend calipers
Hey guys I purchased some 95 legend ls coupe dual piston calipers and I was wondering what pads do I use on the calipers. I never did a caliper swap before so I need some help. I already have pads for my car which is an 03 tl type s. But it doesn't seem like the pads fit. Please help guys I really want to install these calipers and slotted rotors on my car.
Old Apr 3, 2008 | 10:01 AM
fsttyms1's Avatar
you use the TL caliper bracket with the Legend caliper. Then you use the TL pads
Old Apr 3, 2008 | 10:51 AM
01tl4tl's Avatar
The legend brackets do not fit the TL- 1-2 mm longer at the attach points
Legend pads dont fit the TL brackets- pads a little longer and too tight a fit
Make sure to swap the calipers side to side so the one with the big R goes on driver side and L goes on passenger side
Use TL brackets (on their same normal side) use TL rotors- TL pads
Grab the springy things of the new bracket and transfer to the TL bracket
Make sure to use caliper grease where ther is contact or movement
Toss the new bare Legend bracket back in the box with the old calipers to return.
Use a squirt can to prefill the new calipers as much as possible, saves time bleeding and helps protect new seals from damage
Bleed order LF- driver front then clockwise around the car LF RF RR LR
Do not push brake pedal to floor while bleeding- place small 2x4 wood block under pedal to limit travel to 3/4 of full- that protects the MC from overextending and damage.
1 qt DOT4 synthetic brake fluid should fix you up
Old Apr 3, 2008 | 08:17 PM
when i bought the calipers i didnt buy the ones that came with brackets. all that came in the box is the caliper(x2), a bag with 2 bolts and washers(x2), two metal rods that are taper to a bigger size on one side(x2), two rubber boots i guess(x2), and 3 very thin metal pieces(x2) that i guess are used to connect the pads ? not sure though. is this job easy enough to do myself along with stainless steel brake lines ? i never did a brake job in my lifetime
Old Apr 3, 2008 | 10:44 PM
bibledriver's Avatar
Something is missing...my
Originally Posted by 01tl4tl
Use a squirt can to prefill the new calipers as much as possible, saves time bleeding. . .
Old Apr 4, 2008 | 12:40 AM
01tl4tl's Avatar
You do not posses the skill set or tools for this job if you are asking these questions
Changing the lines can be a pain
Make sure to tell the tech to swap them-- L goes on passenger side R goes on driver, so the bleeder is on the top of the caliper once installed
Make sure to clean and lube the metal sliders and such as described before- you will just be using your old parts
You wont need those shims with the TL pads
Old Oct 13, 2008 | 03:59 PM
DEPTLS's Avatar
so i'm guessing that we can of course use TL pads still right? when i get the calipers i put the R on the drivers side and the L on the passengers side and i just pop on the new TL brakes?
Old Oct 13, 2008 | 04:22 PM
pokes717's Avatar
Legend Swap
I'm going to do the same for my sons 99 TL because those brakes stink not to mention the pulsating crap.
Old Oct 13, 2008 | 05:31 PM
fsttyms1's Avatar
Yes
Old Oct 13, 2008 | 06:49 PM
ChucksCL-S's Avatar
I just did this, you can just slide the calipers off and leave the pads and rotors alone. Just slide the new ones right over the old pads, bolt 'em up, bleed them and you are good to go. Previously I had upgraded to slotted rotors and EBC red stuff pads.
Old Oct 13, 2008 | 07:34 PM
DEPTLS's Avatar
hey fsttyms1 I've got some EBC Greenstuff pads being shipped to me, what type of rotor set should i buy? anyone else have ideas?
Old Oct 13, 2008 | 07:39 PM
fsttyms1's Avatar
I like the Rotora rotor (Excelerate), DBA (Tirerack) rotor is supposed to be great and Racing brake (heeltoe) makes a good rotor
Old Oct 13, 2008 | 08:14 PM
phipark's Avatar
Not Asian
I'd recommend DBA rotors. I'm very impressed with mine.
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
Euro4gen
Dec 12, 2015 03:14 AM
lanechanger
Oct 13, 2015 10:56 AM
