led ideas
Old Sep 29, 2009 | 01:58 PM
taintedplay's Avatar
led ideas
ok, a few months ago i bought led's from ledautomotive. theyre almost all burned out. the only ones that are left are the climate control screen and the defrost button. the others have all burned out. (im guessing the fuses provided were a little weak and overtime burned out)
\what can i do to get led's back?
also, the guage cluster still works but is very dim. is there a way to get a solid blue strong light? other than send it to the guy who charges a few hundred
Old Sep 29, 2009 | 06:34 PM
Rajca's Avatar
wham bam thank you ma'am
u have resistor ?
Old Sep 29, 2009 | 06:48 PM
jjashaa's Avatar
Avant Garde Wheels
Originally Posted by Rajca
u have resistor ?
thats what im thinkin...
the DIY's i've seen, they add a resistor too all the LEDs they've added to any dash lights.
Old Sep 29, 2009 | 06:50 PM
Rajca's Avatar
u can buy some with and with out leds
Old Sep 29, 2009 | 07:12 PM
They had resistors. I have some 3mm LEDs laying around with correct resistors, should I try to use those?
Old Sep 29, 2009 | 07:48 PM
It's Clutch's Avatar
Hello Officer
You can try if its the correct size LED.. If your using blue, make sure you have 560ohm resistors. 560 for the brightest (Minimal resistance)
blacktsxwagon
Oct 27, 2015 10:12 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
MikeJM310
Sep 24, 2015 07:24 PM
eastcoastguy
Sep 23, 2015 06:29 AM
