LED Door handles installed on switch...
I spent all day today wiring four LEDs in the doors handles and then wiring them all to one switch in the instrument panel. I installed 12000K head lights too...
comments?
comments?
getting the wires thru the rubber boots was a pain in the neck right? i wanted to hit my tl with a bat when i re wired the audio wires in the doors.
looks cool, i think you should have it come on when you unlock tho, that is baller
(for all 4 doors)
Originally Posted by fsttyms1
Thats a 5 min job
(for all 4 doors)
(for all 4 doors)
^ true story. the wire hanger is hanging off the garage rails
why did you make a switch for the handle lights and not tap them into the dome light? it looks like excessive work.
I used a zip tie....i'm cheap can't waste a coat hanger. I found it easier to pull the boot off the frame and then feed it through that way. Also i just needed to peel back the foam behind the seatbelt tensioner a little bit and feel inside for the wires to snake through. Just a little help to others who tackle this project.
Originally Posted by dreem1er
the leds look good and i think its much better than with a switch then wired to the dome......and kris whats up with the new avatar......
Kirs New avatar is SOOOO :theghey:
Kris your cool as Hell but YEAH what up w/ Ur AVATAR
I still prefer them to turn on with the dome llight, but I can see why having a switch would be nice. The wires through the boots is pretty easy after you do it once, just put a straight length of a coat hanger all the way through the boot then bend a hook into the side the wire is coming through and tie the wire around the hook and pull.
And I think Kris is just bringing something to light about Batman that we have all suspected for some time, but don't really want to believe and is hard ro accept. Why else would he keep brining in new Robins after they got killed? Or give him that gay red and green suit for that matter?
rockyboy
Aug 4, 2024 10:35 AM
tman570
Jun 11, 2019 07:56 AM
EE4Life
Sep 11, 2015 10:13 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
i just got a chuckle out of it when i saw it for the first time
lol.
