LED dash board convertion
half of mine old led in my dash board is out. i know the newest LED doesn't require solder. my question is, does anybody which type of led should i get. t3, t4 or t5?
any help from you guys would be great appreciate. also thank you in advance.
You cant just replace the bulbs with LEDs and get a good result. At the bare minimum, you should remove the film tint on the gauges, which will require work.
The real LED cluster requires soldering. Replacing the bulbs won't look that good.
hm...angel eyes sounds pretty good idea. does anybody know what size do i need to get for the rpm, speed odometer and the gas/temp gauge? and what do i need to do to secure it so i wont fall off ?
this is the one i'm talking about
http://www.ebay.com/itm/10x-White-T3...-/151172390897
This is mine. Further down the page you will see how many mine had in it.
https://acurazine.com/forums/showthr...&highlight=LED
wwoowww, i didn't realize how much additional you added on. I think i might go with the angel light. who do you recommend i should get it from. but i kinda want to have 2 tones on each gauge. white on the bottom and blue on the top ( redline ).
again, thank you so much for ur input. really appreciate
Just buy White. Take the faces off carefully and strip the green coating off the back of them. From there you can use a sharpie or colored film to lay over the area you want different color. Or you could get RGB led halos and change them to any color you want when ever you want.
I usually get all my stuff from http://www.theretrofitsource.com
Or
http://www.superbrightleds.com/cat/l...accent-lights/
But im sure you could get "cheaper" stuff elsewhere.
Or
Jul 16, 2017 07:33 AM
ExcelerateRep
Oct 14, 2015 08:20 AM
