Leaking rack!
Leaking rack!
No, it's not about a breast augmentation gone bad.
My steering rack is starting to leak from the seal at the pinion.
I have almost 190 thou. and if I turn the wheel with the engine off I will get a leak at the rack from the pinion seal where the steering column connects.
I have added Lucas stop leak so I hope it postpones the inevitable.
Replacing the rack is a costly PIA!
Does anyone else had to deal with this?
I would really appreciate your feedback.
replace the seal?
Stuff that fixes leaks are just a temporary bandaid. You might be able to do the work with it in the car. If not you gotta remove it.No other way.
