Leaking rack!
Old Oct 24, 2011 | 07:20 PM
RC99TL's Avatar
Leaking rack!
No, it's not about a breast augmentation gone bad.
My steering rack is starting to leak from the seal at the pinion.
I have almost 190 thou. and if I turn the wheel with the engine off I will get a leak at the rack from the pinion seal where the steering column connects.
I have added Lucas stop leak so I hope it postpones the inevitable.
Replacing the rack is a costly PIA!
Does anyone else had to deal with this?
I would really appreciate your feedback.
Old Oct 24, 2011 | 08:55 PM
fsttyms1's Avatar
replace the seal?
Old Oct 24, 2011 | 09:47 PM
RC99TL's Avatar
I know. But removing the rack is a serious pain.
Old Oct 25, 2011 | 08:53 AM
fsttyms1's Avatar
Stuff that fixes leaks are just a temporary bandaid. You might be able to do the work with it in the car. If not you gotta remove it.No other way.
Old Oct 25, 2011 | 09:43 AM
RC99TL's Avatar
Cant get to the seal without pulling the rack
Old Oct 25, 2011 | 04:37 PM
Karanx7's Avatar
Unregistered Member
You can buy a lot of PS fluid with the $ it would cost for the rack fix. Live with it and refill every now and then?
Old Oct 25, 2011 | 06:21 PM
jnkracing's Avatar
Dropping the rack isn't the worst part by a long shot. Disassembling the rack, installing the seal and hoping it seats correctly is. I'd replace the rack with a used unit as a quick fix
Mike734
Dec 10, 2021 01:25 PM
Avenger411
Oct 11, 2015 03:53 PM
steve
Sep 30, 2015 09:23 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
