Late model Tranny failures, Root Cause?
This is disturbing. I thought that the tranny failures were solved
by the time the 2001/2002 models were released in mass and
certainly before the 2003 model. (thought 2000 was the worst)
My understanding is that the 3rd gear clutch packs were the culprit.
However I'm now seeing 2003 failures on this board and wonder
if the real root cause of these failures has beed identified.
Tranny failures like this are a real black mark for Acura. Trannsmissions should be as or more reliable than engines nowdays.
Anyone run across year by year failure stats?
/Steve
/Steve
Yeah, its STOCK!!!
Originally posted by `ill*tl
Some of the '03 tranny problems you see on the board are early model '03s...
-jason
@ slide or die @
in on a '99TL with 65K miles and im still in the first tranny... i think its only on the 00-30 models with 5speed problems...Of course id rather have 5 speeds and replace my tranny every 20 than a 4 speed...
LiQice: Thanks for the lnk. That is a WEALTH of good information!
The general feeling I'm getting from reseach is that there are some minor engineering problems but that the biggest fault is that the tranny engineers did not keep in synch with the engine engineers. The tranny seems unable to tolerate the engine output over many miles. Underengineered. I wonder if the tranny is near identical to that used on lesser powered models like the 99 and earlier and or other models.
/Steve
/Steve
what car never had a bad tranny??? every chrystler made has tranny problems
6G TLX-S
But now there are two issues :
(1) It seems like Honda has still not located and fixed the root of the problem, or has found a fix but the corrective update would be too costly to perform.
(2) Everyone expect Honda cars to be reliable.
Come to think of it we had two Saabs (86' and an 88') that went south by way of the (auto) transmission. There are two different types of fluid in those things that is sepeerated by a seal. If that seal goes bad and the fluids mix then that trans is shot.
Then again, one of my first cars (though not street legal) was a Mopar with a 727 Torqueflight. Now that thing was bullet proof!
the transmission failure is do to a output bearing, the metal is simply too soft and eventually it sheds peices of metal thuoughout the transmission fluid which destroys the clutch packs, the reason it has taken them so long to figure out is becuase when every transmission is replaced the mechanic has to strain all the fluid, to look for particles and what not....however the particles were so small they were goin through the strainers. unfortuantly this was recently discovered and they transmissions they replaced are still failing becuase the same faulty bearings were installed. sorry its so long.
6G TLX-S
The failing clutch packs almost always belong to the 3rd gear. So it means that the tiny little metal particles, circulating throughout the transmission, are capable of homing in towards the 3rd gear clutch only !! Sounds so much like an X-file.
Another thing to consider is that even the tranny replacements are failing, and yes, I mean current replacements. So if the problem had been resolved in the production 2003s, why are the replacement trannies now being used failing?
Liquid Ice
Originally posted by LiQiCE
The majority of the problems with the replacement trannies are due to the tranny being installed improperly (bad seals etc).
6G TLX-S
To remove the old tranny, a few plastic cover pieces need to be removed, tranny oil drained, motor mounts bolts unbolted, electrical connectors disconnected, other mounting bolts unbolted, suspension parts bolts unbolted, half shalfs removed, engine lifted, tranny bolts unbolted, and rebuilt tranny finally replaced. I may have missed a few steps, but this is generally what’s being done.
If the job is done right, the car will drive; if the job is not done right, the car won’t drive. But I just can’t see how a rebuilt tranny, that someone claimed was incorrectly installed, could be driven for a few or even a few tens of kilo-miles before failing again, and failed the same way - slipping 3rd gear clutch !!
Factory rebuilt trannies have already had a few revisions done. Obviously the earlier revisions didn't really solve the real problem(s). That’s why we see repeated failures from rebuilt trannies. The latest revision involves replacing the PCM as well. Let’s hope that Honda has finally got to the bottom of the problem(s).
Rebuilt trannies are replaced by Honda-factory-trained mechanics. They have detailed factory service bulletins to follow through. They have all the right tools to do the job. How can the trannys be installed incorrectly ? But I wouldn't be so sure if the job was done by a high school drop-out in a corner gas station garage.
Please give credit where it belongs.
8th Gear
Non S TL also?
Is it only the S-type TL having the problem or is the regular TL tranny also failing?
I realized the other day that these trannys don't have a filter, nor is there even easy access to the screen inside the tranny. Maybe this is the problem. (?)
Do you guys change your tranny fluid on schedule? What type are you using? Anybody use Mobil One?
Hmmm .. interesting post .. my suggestion to everyone is .. visit this post to see pieces of the report filed by Honda to the NHTSA in regards to the investigation of the 5 speed auto (NOT the 4 speed auto which is failing for different reasons). http://www.acura-cl.com/forums/showt...hreadid=104677
After reading the report, you will see that the failing tranny has MANY issues .. some of which are basic design by our beloved Honda *cough* *cough* .. SERIOUSLY poor quality contron issues during manufacturing ... POOR testing of the product as a whole .. and yes .. a high level of stupidity in believing they have a problem.
I for one do NOT believe that Honda has done anything more than bandaid their 5 speed auto in order to attempt to hold it together until their *cough* *cough* generous warranty extension obligations are met .. I personally feel that the real fix will cost far more than Honda/Acura is willing to spend to keep its owners happy and safe.
But yes .. ALL 5 speed auto trannies are subject to these problems .. doesn't matter if it is a type-s or not .. doesn't matter if you change your fluid every 2 days .. the problem is in the most basic design and assembly.
Still sluggin' it out
![Cheers](https://acurazine.com/forums/images/smilies/cheers.gif)
Jamus22
06-11-2023 10:08 AM
mlody
12-04-2019 02:11 PM
Pham Alvan
03-16-2016 09:17 AM
