K&N Intake Install Help - DYI anyone?
I need to install my K&N air filter. Right now I have just simply replaced the stock air filter with a K&N cai. I need to know how to remove the box that has that radiator thing in it with the 2 hose.
It is for a '99 3.2 TL
Anyone with photos?
Help is appreciated.
Thanks,
Mike
Anyone with photos?
Thanks,
Mike
It's the Halladay season!
You should check the DIY thread. Most of the time, you'll find what you're looking for.
Look I found this...
http://wizardsworks.org/chod/acura/cai/printme.html
Look in the DIY section for Intake Resonator delete or resonator removal
Depending on year, there is 1 or 2 bolts holding the thing in
You may be able to move the left-driver inner fender plastic and reach it.
Otherwise remove the bumper cover- a few clips and bolts-
have friend on hand to move it safely off the car- now the box is right in front of you!
make sure to get the small plastic piece that tries to stay behind
You want free-clear airspace going to the 2 larger holes on the bottem of the airbox
If your car has the fake fog light openings
Cut the driver side open- either completely remove it with a dremel or cut between the lines with dremel so its a hidden opening in the grill
That will get even more outside air to the area
cycdaniel
12-17-2019 10:58 AM
nanos
11-12-2015 08:41 PM
Abe_Froman
09-16-2015 01:27 PM
