Just wondering...NSX engine
Originally Posted by corpsdawg
Thats my whole argument for the K23, regardless of it's practicality
The K23 is in an AWD car, How would it do in a FWD? I doubt the K23 would even put that to the wheels.
I don't think it'll even pull as hard as a Jseries would, regardless what's on paper.
Originally Posted by InspireTL
BTW, torque wins races.
I think it could put the power to the wheels. The 0-60 time of the RDX is real close to that of the 2nd gen Type-S, but this is also in a car that weighs almost 500 pounds more than the TL. Agreed about the transmission and drive-train issue. Anyone have too much money and want to fabricate a solution to putting the K23 in a front wheel drive car? I wouldn't mind seeing the first SH-AWD TL being a 2nd Gen TL
Originally Posted by fsttyms1
Tell that to the viper which looses races to the less torque ZO6
LSx>Whatever 8.x-liter V10 the viper has..
Not a Viper fan.
Isn't the vette lighter than the Viper anyways?
You guys want torque, Build a 3.5 and FI it. It would be cheaper to do that than to try to convert a K series into the car. Not to mention it would produce A LOT more HP and Torque to the wheels.
Originally Posted by mrproul
somebody should put an NSX motor in an integra. it is like the H22 motor that somebody made a Mid engine RWD out of the integra. that was awsome.
It was cool for the first few times it was up.
This has been briefly discussed on the 3rd gen forum, but is it possible to stroke the 3.2 to a 3.7? If its not possible now, does anyone speculate that it would be more likely in the future with a 3.7 going into a version of the 4th gen?
He loves to guinea pig these kinda things.
Trolling Canuckistan
The NSX engine isn't really all that special byt itself. The NSX as a whole on the other hand is an incredible car.
The major complaint against the NSX was it's lack of power but it made up for it with incredible balance and handling. I think it would make more sense to swap a TL-S 3.5 into a NSX than a NSX 3.2 into a TL.
It is possible. A good friend of mine is working on it.
I would really like to see that and proof of what he did to achieve 3.7 out of our motor!!!! Until that i dont believe it.
It is for the 2nd gen J-series which involve the 04-06 tls, 03-07 accords.
The J37 crank will fit into those blocks making it a J36 instead of an j37.
None of this is relevant to what we are talking about here.
Again, sorry.
But now since it's been mentioned, an old friend of ours is going to guinea pig this idea.
Well,
Not a Viper fan.
Not a Viper fan.
And yes, its lighter.
Girlfriend's dad has one pretty heavily modded. Its scary lol. We beat the shit out of a street bike the other night.
acutally the NSX motor is very well built. Lovefab has taken advantage of it and there are crazy amounts of power coming from NSX's.
A brand new NSX motor costs about 35K, with all parts, no that is not a typo, 35K
A 1991 NSX with high miles should be around 19K, and a slavaged NSX with a good motor is less.
Buy a slavaged NSX, get the motor redone by S.0.S (science of speed dot com) for 15K to brand new specs and 3.8 bore.
Then drop it into the TL bay (it will fit), figure out the transmssion systems and other systems, then send it into lovefab for their kit.
At the end of the day, you will have a 700+ WHP FWD car.... for around 40K....
this engine couldnt be all motor at 920whp. If it is it's not running on pump gas. Whats the compression on this engine? Whats the unbored cylinder size of the nsx engine?
You mean stock or the modified?
I'm going to correct your units real quick. Torque is not power, HP is.
Horsepower is a function of torque and RPM.
The stock engine bore
Engine Displacement 3179 cc (194 cu in)
Bore 93 mm (3.66 in)
Stroke 78 mm (3.07 in)
Bore / Stroke Ratio 1.19
10.2:1 compression
1995
Engine Displacement 2977 cc (181.67 cu in)
Bore 90 mm (3.54 in)
Bore / Stroke Ratio 1.15
10.2:1 Compression
SidhuSaaB
May 30, 2020 12:40 AM
joflewbyu2
Oct 8, 2015 11:16 AM
STL TL-S
Sep 23, 2015 08:52 PM
