just seafoamed
B A N N E D
1 Post
just seafoamed
I used a can of seafoam, I let it suck thru the vacum line. man there was a ton of smoke comin out the back when i drove it. but the car seems to be runnin smoother. i have one more can, what do u guys recommend i do with it?
when you get down to 1/4 tank of gas- toss in the contents of the seafoam can- no prob at that ratio- its super cleaning strength is all
Dont put in oil until ready to change right away
Make sure you did they 4000 rpm hard revving lots of fun 20 minute engine clean- out after seafoam- and it sits for 5-15 minutes after you put it in- then drive
Do again in 2000 miles and good for a year
T-Swzy
Here I am!
No-- revving at home does not cause the same type of high heat you need to dissolve 6 years of crud that are now all sticky and wet in the engine. The cloud only stays with you a few blocks- I do that as I leave the neighborhood- then hit the freeway= go to 3000- hit it to 5000 and back down- repeat over and over till smokes no more- then a little cruising for fun
The gas tank method cleans the injector spray pattern- thats good for everything!
acuratl26
04-23-2020 07:30 PM
EPS CL
06-02-2009 11:16 PM
manteuffel
03-12-2006 11:12 PM
