Just installed Anti-Roll ("Sway") bars!
Not a Blowhole
They were Comptechs, did it myself, no problems whatsoever. I already had a 5mm male hex socket so that is what I used to loosen the end links.
My kit came only with the PTFE tape. Just to make sure, I called Comptech and "Joe" told me that they have decided to go with the tape over the grease.
I am overall delighted with the improvement. Most of the roads here are smooth, very little skittery, crowned roads as you see in New England. I think if I lived in Connecticut I would not install them, as they do reduce compliance and wheel independence in corners where there are irregularities as you radius through.
They add a small amount of harshness on expansion joints in straight ahead driving, but as I am performance oriented, this was not a deal breaker.
If you are contemplating only a simple mod, this one is hard to beat - I should have done it earlier.
So, I guess I am done..as if! There are RES and new mystery mods galore ahead.
Replaced my OEM sways a couple of weeks ago with the Comptech sways. Took about two hours but no probem if you have the proper tools especially the hex.
When I removed the OEM front sway bar and compared to the Comptech bar, there did not seem to be much of a difference. I weighted the bars and the weight was the same. Not sure if there is any difference between the OEM front sway bar and the Comptech sway bar. However, there is a noticeable difference in the size of the rear sway bars.
Also have the Neuspeed front strut bar. IMHO, didn't see that much of a change in handling after adding the strut bar and changing out the sways.
Also added a DEI shock sensor that weekend as well. Well worth the $25 investment.
1 Post
RR - I can't believe you're just now getting around to doing this! I just assumed you had these all along (shows how much attention I pay!) Good move, welcome to the machine.........
dj5 - are you stating you didn't feel a diff after adding the sways, or just after the Neuspeed upper. I'd agree with the Neuspeed upper on our cars, really not much diff. On my mom's Accord, it made all the diff. in the world (as they have no OE strut brace that connects between the towers.)
The Comptech sways on the other hand are like night / day on our cars. A no-brainer for the enthusiest.
Jim
Jim
Did you add the shock sensor yourself?
Thanks,
Cap
WayTooManyAcuras
Re: Just installed Anti-Roll ("Sway") bars!
(That is, those of us that can actually DRIVE our TL-S's. [Those with trannys])
Good luck with them.........
:-jon
Guest
Posts: n/a
I kind of want the sways because I drive the canyons a lot here in so cal, but then again, the roads to have their flaws and it sounds like I'd pay a price in ride comfort by doing it.
See, I love to drive hard, but most of the time I'm with my gorgeous woman by my side. And you know, she's holding my hand and stroking my arm and we're talking and driving and life is blissfull. Sway bars don't sound like they'd compliment my every day driving. But when its time to blow through traffic, or tear down Mulholland drive, I'd probably love them even more than the hand holding and arm stroking.
Does that make sense? I know most of you guys are young, single and out there looking for excitement at every turn....
Originally posted by Caprirooster
dj5,
Thanks,
Cap
dj5,
Thanks,
Cap
Hi Cap,
Yes, installed the shock sensor myself. Took about 15 minutes.
I ordered the DEI shock sensor from www.autotechs.com.
Used the instructions from this site for my install. The instuctions from http://www.acura-tl.com/forum/showth...r+installation
http://public.fotki.com/novawhitety...sensor_install/ were the best instructions but don't seem to be able to access now. I may have a hard copy that I could send to you.
Re: Re: Just installed Anti-Roll ("Sway") bars!
Originally posted by oblio98
Hey RoadRage! We "Nutmeggers" like our sway bars too!!
(That is, those of us that can actually DRIVE our TL-S's. [Those with trannys])![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
:-jon
:-jon
(I'm on my 2nd tranny too, POS got completely stuck in 2nd gear AGAIN today too...
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
1 Post
Originally posted by snook789
Yes the difference in the front is Comptechs is a solid bar...
If that bar was solid, you'd know it (when lifting it!!!)
Maybe I'm wrong, but that's the info I got!?
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
Not a Blowhole
Nutmeggers:
I spent 18 years of my life in Stamford, know the roads well! Roads here are generally flat and billiard smooth, so they really respoond welolo to a low roll center. The roads I recall in Westport, Fairfield, Ridgefield (Beverly Hills East) were paved cow paths, with crowns and lots of bumps, wjere suspension compliance is important, and tuning similar to German cars (loots of wheel travel) is more advantageous than US tuning (stiff, such as sprined/barred TL)/ I am not saying it won't work, just might not be my cup of tea for the roads I know there.
Hyde:
After I did the springs, I guess I doidn't think the anti-tollo bars would make a signficant improvement - i was wrong - they do. So I guess I was dumb, fat, and happy.
Hyde:
NOT
The Comptech front sway is hollow just like the OEM bar.
The rear sway bar is solid.
NOT
NOT
I don't think Tim is right this time. Comptech front sway is not solid, just has a thicker inside wall. I kinda doubt that also, since it ways just as much as the stock bar. Considering that comptech doesn't even make the busihing for the rear sway that they include in the package, i got a feeling all we are really getting is a bigger rear sway.
Not a Blowhole
I do not see what the confusion is - the front bar is hollow, the inside wall is thcker, so it is stiffer. That is Advantage 1.
The rear bar is thicker and stiffer. Advantage 2.
The rear bushing appears to be polyurethane, less resistant to flexing, more precise location of the bar. Advantage 3.
So the way I see it, Ctech gives you 3 benefits.
1 Post
Originally posted by mackdaddy
Agreed. This shoudn't be an issue with you all, you know this!!!!
Comptech says that the walls of the front sway bar are thicker, but i'm not 100% sure that is true. I weighed both the OEM and Comtech bars on a scale (not an extremely accurate scale) and saw no difference in weight. Would think if the Comptech bar had thicker walls it would weigh more. Maybe it performs better somehow but to me they looked identical. If sold seperatly, I would only buy the rear Comptech sway bar.
I have them on my car and will leave them on. Bought both the Compech sways and Neuspeed strut bar from this site. Great service..
Purchased: April 28, 2001
Believe me, I've done a butt load of research/phone calls when I was trying to decide which sways to get. Comptech claims that the front side walls are thicker, but unless anyone has any measurements, then we're only going by faith. I for one weighed the front bar myself stock vs Neuspeed and let me tell you, although I may have lost the data (since I didnt really care for it since the scale was only a household one, and didnt find the result too legitimate), I do recall that the weight of the aftermarket Neuspeed bar was almost doubled. I also pondered with Tim and asked if the Comptech bars can be sold seperately, but since it was not, I opted to go with Neuspeeds.
As for the people saying that having a too stiff of a rear bar will cause oversteer to be true, you are not taking into account that the front sways are also completely solid, and that the weight and stiffness of the front will still be greater than the rear unlike if I went with the Comptech front and Neuspeed rear setup. I have tried many times to try and spin out on a nearby parking lot doing slaloms (dry pavement, and the parking lot was big enough to reach at least 80 mph...it's for a horse race track) and have yet to complete a 180 degree spin. Since my front is still 2mm thicker than the rear and both bars are solid, I still experience the same understeer as I would with any front wheel drive car. The one thing I do recall though is that I never turned VSA off, so maybe next time I go and show a friend what sways would do for handling I would try the same runs with VSA off.
P.S.
The last time I did a run around the parking lot to show my uncle what sways bar do, I walked around the car to briefly inspect the exterior body and let me tell you, I've never seen sidewall damage as bad as the one on my right front tire. When I gave the controls to my uncle, for some reason he would favor one side over the other and we would do nothing but full throttle counterclockwise circles. After seeing the effects of my run on a 215 size tire, I wonder how bad it would be if I changed it to a 235/45 size tire using the stock rims.
(If Yokahama offered the AVS db on 215, I'd get that instead...but 235 is the smallest I could go on that make of tire)
P.S.
Hi Cap,
Hi Cap,
cycdaniel
12-17-2019 10:58 AM
MonkeyTrucker
09-21-2015 06:15 PM
