just got my tranny fluid flushed..
Old 09-18-2002 | 09:33 PM
numbaonexstunna's Avatar
omg. my car runs so much smoother............when i accelerated slow, the gas pedal used to shake a little only at 1800 rpm..i figured it was something wit the tranny............
paid 167$ and its worth it. more smoother shifts also
Old 09-19-2002 | 03:18 AM
69tl's Avatar
how often or how many mile do I have to flush my tranny fulid??
Old 09-19-2002 | 09:12 AM
Mr Zipps's Avatar
Is it possible to fully flush the tranny fluid myself. If so how is there a website or do you have step-by-step instructions.
Mr
03 ABP TL-S
New Jersey
Old 09-19-2002 | 09:50 AM
fender4's Avatar
The correct FLUSH procedure per "JENS and Acura Service" is to 1) drain put in two qts, run 3-5 minutes while shifting between gears (YES KEEP FOOT ON BREAK) 2) repeat "1" three times, final fill is 2.75 qt. The fill plug is on top of the trans and is marked "ATF"; makes this job easy. I did it in 1 hr and the 9 qts of oil cost me around $48. Remember use only "Honda Z1" atf. I contacted a synthetic oil company (Amsoil) and their engineering dept said use only HONDA ATF. Mobil1 web page also said to use only Honda Z1. Not a 100% flush but good enough..
Old 09-19-2002 | 11:27 AM
StanMan's Avatar
i did it at 15k and again at 30k, so i guess i'll be doing it at every 15k...
Old 09-19-2002 | 04:10 PM
Bfor3's Avatar
Where did you get it done at Stan and how much?
Old 09-19-2002 | 10:36 PM
i duno..they hooked up pumps or soemthin.....sounds too complicated =)............ima do it every 10k miles
Old 09-20-2002 | 03:35 AM
roadman's Avatar
Acura uses the same process that Fender4 describes, after having them describe it to me after the first time I have done it myself since. The drain plug always has metal dust on it so I do a partial flush (2+qts) every 3-5K. It does not seem to make any difference though 1St Tranny gone at 28K second one is due to be replaced in a week at 43K. Perhaps an in-line filter or an oil cooler may have prolonged the inevitable. It is hard to imagine that dirty fluid that is maintained on a more that recommended interval could cause a tranny to fail.
SidhuSaaB
05-30-2020 12:40 AM
LeVeL
10-18-2015 04:19 PM
lanechanger
10-13-2015 10:56 AM
xsilverhawkx
10-05-2015 11:00 AM
ROSSARONIE
09-22-2015 11:46 AM
Quick Reply: just got my tranny fluid flushed..
