jiggling rear view mirror
whats causing it to jiggle? stereo? just driving? ???
Show me da MONEY
Mine wiggles a lot when I turn my radio up or if I go over rumble strips on the road. I remember a while back, that a black ring fell off of the back of it (never put it back on because it cracked in half, don't know how it happened), that's when the looseness started. Any suggestions how to fabricate something to stiffen it up again....
NiGhT rIdEr
Originally Posted by actright
as much as I like jiggly things, rear view mirrors are not one of them. It has like a cap thing, but no screw thing up in there. Any tips?
i had mine jiggle for a while, then it fell off, the dealership changed it under warranty, now i'm at 80k miles and it fell off again, i just used some tar type stuff it stuck it up there.... mine fell due to my TV being there....
Originally Posted by Southern
Lighty tap the mirror bracket at the bottom upwards. Use the palm of your hand or a rubber mallot. The bracket uses a tappered channel and your mirror is loose because the bracket has slid downwards.
very informative thanks
Flyin' and Drivin'
That should fix the problem!
I'm not sure if mine came loose because I replaced it over 1 year ago (under warranty from the mfg) and didn't have it secure enough or if was due to the 100+ temperatures in Chicago. Either way its rock solid now.
I've had the mounting bracket for the rearview mirror break going over a couple of potholes. Had a plastic thing hit me in the face when it happened. That made the mirror really loose. I took it to the dealer and it was replaced under warranty.
BoricuaTL
04-08-2016 01:08 PM
dre707
09-08-2015 08:32 PM
