JDM window visor question
Old Jan 30, 2008 | 09:59 PM
merkin110's Avatar
I just picked up a set of used JDM window visors. My question is, is it neccessary to remove the old double sided tape and apply new double sided tape?
Thank you
Old Jan 30, 2008 | 10:55 PM
Malayalee King's Avatar
ഥഎണഡഏ Fellas Inc.
if they're used, i would.
Old Jan 31, 2008 | 09:57 PM
merkin110's Avatar
I got it installed with the double sided tape but how the hell do I put the clips and screws in?
Old Jan 31, 2008 | 10:13 PM
Max Boost's Avatar
were can i get some of those visors
Old Jan 31, 2008 | 10:26 PM
merkin110's Avatar
I got it used from the black market but you can purchase the oem honda inspire window visors from our vendor MrHeeltoe. But just to warn you it could take over a month to get them. Otherwise you can go the cheap route and get weathertech window visors. Anyways back on topic. Can anyone tell me how to install the clips and screws?
Old Feb 1, 2008 | 02:56 AM
SLAKERZ's Avatar
CITIUS::INFERIUS::FORTIUS
https://acurazine.com/forums/showthr...ht=rain+guards
This is the thread that helped me the most. It's hard to explain, but basically you take out part of the rubber window lining where the clips are shown on the Japanese instructions. Hold the visors up to the window and align them where they're suppose to be. The tabs at the ends should help you hold them up a bit to align, insert the clips (one at a time, make sure they're on the right way), align the clips with the screw holes on the visor, and shove the window liner back in as you go one clip at a time to hold the clip in place. Then screw in the visor to the clips, making sure the tabs at the ends are secure. After that, I just pulled on the visors so there was a little gap between the car and the visor and took off the double sided tape strip. Made sure it was aligned and pressed on it. Make sure your window liner is shoved back in and smoothed out. Hope this helps somewhat haha. It's tricky, but in the end, pretty easy.
Old Feb 1, 2008 | 08:59 AM
merkin110's Avatar
I already applied my double sided tape. Is it still possible to put in the clips?
Old Feb 1, 2008 | 09:07 AM
mezzerTL-S's Avatar
New ride...Acura MDX 2013
IMO you should've bought these ones, no tape + no clips = no hassles. Just pressure fit and away you go.
http://www.weathertech.com/store/mvp...Id=8&Year=2002
Old Feb 1, 2008 | 10:11 AM
merkin110's Avatar
Thanks for your input but IMO the honda inspire window visors flow much better than weathertech.
Old Feb 2, 2008 | 12:19 PM
Max Boost's Avatar
can you post the pic to see how the inspire one look?
Old Feb 2, 2008 | 04:28 PM
SLAKERZ's Avatar
This thread has a great comparison between the Weathertech and JDM
White = Weathertech
Black = JDM
https://acurazine.com/forums/showthread.php?t=170327
I'm not sure if you can still put in the clips after you put the tape on. It seems possible though.
Old Feb 3, 2008 | 03:37 PM
JDM Inspired's Avatar
Thumbs up
i need sum Visors.......it sucks when it rains and you dont have any and the polluted rain water falls on your sexy door panels.......
Old Feb 3, 2008 | 10:22 PM
Razzi's Avatar
T-Swzy
it's nice not having shit fog up during the rain lol
Old Feb 4, 2008 | 02:20 PM
Max Boost's Avatar
whats the difrence between both??
BoricuaTL
Apr 8, 2016 01:08 PM
Iakonafuji
Sep 21, 2015 02:39 PM
datadr
Sep 12, 2015 09:12 PM
ahsm
Sep 9, 2015 08:35 AM
nuldabz
Sep 3, 2015 05:49 PM
