jack point got jacked up
I was trying to an oil change today. I've done a few myself before. My friend usually jacks it up for me cuz it's his hydraulic jack, but it's not like I don't know how it's done. I've changed a spare tire before and know how to jack up a car.
Well anyways, after positioning the jack underneath the point, I began pumping. I was getting close to being able to slide woodblocks underneath the tire when I heard a twinge in the spring of the jack. I looked under and saw the jackpoint smooshed. Somehow the bar thing folded over
I lower the car and removed the jack. That's when I noticed the asphalt ground had caved in where the jack's wheel's were.
here are pictures to go with my words. http://www.pbase.com/ants/dannys_tl
Please give me your thoughts on why this happened and what I should do about it.
I lower the car and removed the jack. That's when I noticed the asphalt ground had caved in where the jack's wheel's were.here are pictures to go with my words. http://www.pbase.com/ants/dannys_tl
Well, the asphalt is too soft (was it a hot day?) and when the jack wheels sunk in, it wasn't able to roll forward thus bending your jacking point plate
Just incase, I would use a sheet of plywood big enough for the jack to spread the weight to more than just the jack wheels.
. Just incase, I would use a sheet of plywood big enough for the jack to spread the weight to more than just the jack wheels.
Same thing happened to me except my stock jack was barely on the jack point. When I got my car just high enough the jack gave way. THE JACK STAYED IN THE UP POSITION AND MY CAR JUST SANK! I looked on the passenger's floor and the jack literally went thru the floor and almost made it thru the carpet.:wow:
I payed 700 to get it fixed... It shouldnt be that hard or expensive to weld it back on...
when u dont have experience with something leave it to the professionals....." dont do the crime if u cant do the time...Beretta "......next time make sure u follow the directions....stay within the lines,,,,,,the lines are ur friend.
Originally posted by NsX Pilot
as far as the plate you can bend it back out or just leave it ...it wont hurt anything
Anyways, thanks for the advice everyone.
Originally posted by TLover8888
you should jack the car up in your garage, which is made out of concrete, not tar.
that remark wasnt aimed toward you danny
Yeh, I'm at my apartment so no garage for me. The entire lot is asphalt, so I figure I'll go park at walmart or something and do the oil change there. lol
Originally posted by TLDanny
...so I figure I'll go park at walmart or something and do the oil change there. lol
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
THE EARTH IS OUR FRIEND
