Its good to be FRESH!!
cuz its a different motor with diff parts. do a search...... type s gauges, tl-s gauges, so on
https://acurazine.com/forums/showthr...ht=type+gauges
but if you really want to tear shit apart here you go
fsttyms1
close
- Join DateAug 2002
- LocationAppleton WI
- Age51
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:3,068 Times in 2,123 Posts
Quote:
From my understanding thats only on the 99. they used a different sending unit setupOriginally Posted by philly fresh
yes but the temp guage will not work
fsttyms1
close
- Join DateAug 2002
- Age51
Also you can buy a used cluster and just replace the faces. Recalibrating things wont be too hard. Just do it without having driven the car so that the temp gauge is cold, have a full tank of gas, speed either with a GPS or a friend on a secluded road get up to a predetermined speed like 50 and place the needle on (test at other speeds to double check correct) rpm, idle warm 750-800
