Installing a Shock Sensor
Old Jun 7, 2006 | 04:27 PM
OntarioTL's Avatar
First of all YES, I did do a search and found NOVAwhiteTypeS install DYI. The only thing is that the link is dead.
Can anyone help me out, or have instructions themselves? I just picked up a shock sensor (DEI) when I was in the states for Cedar park.
OntarioTL
Old Jun 7, 2006 | 08:05 PM
NOVAwhiteTypeS's Avatar
ahh the shocksensor so it still lives on LOL heres pics:
http://joekim1113.fotki.com/cl/shocksensor_install/
I renamed my fotki account.
Old Jun 7, 2006 | 08:44 PM
JMAL's Avatar
sweet i was gonna do this too. but i thought dei was a bad one to get?
Old Jun 7, 2006 | 08:57 PM
OntarioTL's Avatar
Thanks for the help and info!!! And yes it still lives as I've been putting this off for a while, but I just happen to see one on the shelf and thought...what the hell...
OntarioTL
Old Jan 21, 2008 | 06:27 PM
Q1911's Avatar
Yes i realize i'm bumping an almost 2 yr old thread.
any one have a copy of these instructions? I've searched and searched and all the links I've found are dead most are from acura-tl.com
Old Jan 22, 2008 | 09:32 AM
JMAL's Avatar
are you coming to the ny meet this weekend? i can explain it to you then if so. its easy. u need a shock sensor(digital single stage prefered but can use dual), t tap, wire end connector to get power and ground. i cant remember off the top of my head, but i can show you the wires on my car.
Old Jan 22, 2008 | 11:15 AM
OntarioTL's Avatar
If you use the link that NOVA shared with me, it will come out file not found...but if you navigate back to home and search photos again, you will find the proper link....ah what the hell here it is.....
Shock sensor install
Old Jan 22, 2008 | 05:13 PM
Q1911's Avatar
imaginary reps from me to you, sir!
Old Jan 23, 2008 | 12:39 AM
burnerjunky's Avatar
Registered Pimp
how would i do this if i want to make it a two stage alarm? or this not possible with a 99tl
Old Jan 23, 2008 | 05:20 AM
JMAL's Avatar
no 2 stage, u tie the 1st and second trigger together
Old Jan 23, 2008 | 04:17 PM
NighthawkBlack's Avatar
I added a glass and shock from dei to my stock one in 2000 and used the radio trigger for the signal to the alarm
Old Jan 23, 2008 | 04:20 PM
JMAL's Avatar
where did you tap that wire.
Old Jan 23, 2008 | 08:03 PM
Rajca's Avatar
wham bam thank you ma'am
what does a shock sensor exactly do?
Old Jan 23, 2008 | 08:06 PM
JMAL's Avatar
the factory alarm only goes off when armed and a door is opened. if someone smashes the window and climbs in( in know from experience), nothing happens. a shock sensor modded into the factory alarm will go off with impact as well as door entry. plus u can use the factory equipment like the fob.
Old Jan 27, 2008 | 09:27 PM
CAB NY's Avatar
Tri State ViP Crew
the link for the reason not to use DEI senors is out what is the reason if antbody knows thanks
Old Jan 27, 2008 | 09:32 PM
Rajca's Avatar
o ok thx for clearing it up for me
Old Jan 27, 2008 | 09:33 PM
CAB NY's Avatar
Tri State ViP Crew
the link on not using DEI senors is out but what is the reason if someone knows thanks
Old Jan 27, 2008 | 09:36 PM
JMAL's Avatar
u can use DEI im pretty sure mine is. im not sure why it said not to, maybe at that time they didnt work, and the current models do?
Old Jan 27, 2008 | 10:39 PM
CAB NY's Avatar
Tri State ViP Crew
mine is works find i was trying to find out why not to use it thanks
Old Jan 28, 2008 | 12:43 AM
NoLimitDeC's Avatar
DESI miern
x2
Old Jan 31, 2008 | 03:14 PM
Q1911's Avatar
ok i no there are many threads on this, i;ve looked at them all and none helped. I cant find the right YELLOW wire to tap into. everyone i tap doesnt work. can someone help me out here.
cab ny any suggestions on finding the right wire?
Old Jan 31, 2008 | 10:05 PM
CAB NY's Avatar
Tri State ViP Crew
check your pm
skathe
2G TSX Performance Parts & Modifications
23
Apr 10, 2020 06:36 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
EE4Life
Sep 11, 2015 10:13 PM
NSolace
Sep 3, 2015 08:02 PM
