Installing OEM kit...help!
Old Nov 18, 2002 | 05:09 PM
ColdFusionTL's Avatar
can some one please help me out with what i can do. Im attempting to remove the stock side skirts but they won't come off. Is there a technique to it? I've been trying to get either side off but its not working. THere are 2 screws in the front wheel well and 4 under the car right? I've been trying to slide the side skirt towards the front of the car. Some one please help
Old Nov 18, 2002 | 05:37 PM
2003TYPES's Avatar
i did mine my self and the side skirts are pain i laid down put my foot agaisnt the rear tire for support and pulled it forward start at the rear and work your way up to the front it will give.then take all the white clips out put on the new skirt and pop it straight on no sliding going back on..
good luck
Old Nov 18, 2002 | 06:11 PM
Mr Hyde's Avatar
check the FAQ on the left for a step by setp on the install
Old Nov 18, 2002 | 06:39 PM
Hstar512's Avatar
i just got mine on 2 days ago and it was a pain to get the side skirts off. I recommend getting a 2x4 or anything really sturdy and leverage it against the rear wheel and just the side skirt and push the board towards the front. Try it, it works!
Old Nov 18, 2002 | 08:04 PM
vojm's Avatar
Like 2003TypeS side start in the rear, grab hold of those suckers, put your foot on the rear wheel as support and use all your body weight and pull the skirts towards the front of the car. If it doesn't budge on the first try keep doing it a couple more times . It'll pop off so don't worry about breaking it.
Old Nov 18, 2002 | 09:54 PM
StanMan's Avatar
after removing ALL the screws, i totally agree with the 2x4 technique! using your hands is not enough and it just makes you think you are going to bend it out of shape. the 2x4 should be wedged at the rear of the skirt and then presssed forward till the skirt slides off the pop pins.
Old Nov 19, 2002 | 12:07 AM
well, i finished installing the whole kit a few hours ago. I swear it makes the car look 10 times better. The side skirts were a biatch to take off but they finally came off. It's normal for the rear lip to have a gap huh? No matter what i did to adjust the back, it always had a gap
Old Nov 19, 2002 | 02:18 PM
69tl's Avatar
yea, I got mine done last week and everything fit perfectly except the one in the back. kinda annoy but oh well i guess that's how it suppose to so i guess i have to get use to it.
HairyMonkey019
Apr 22, 2016 10:50 PM
bailey24
Nov 21, 2015 08:43 PM
nanos
Nov 12, 2015 08:41 PM
InFaMouSLink
Oct 27, 2015 06:51 PM
MyKids&Cars
Sep 1, 2015 12:53 PM
