Installing the bodykit
Mr. 2tone
i just bout OEM front n sides...n i should b getting the front 2morow...i just got a couple of questions...is it easy to install them?...n does it take long?...n as for my rear...my WW rear is gona b paint next fri...is that any different from the normal installation of the OEM rear?...im asking kuz i dont even know how to take the front bumper off...lol...thx guys...
i would say its a pretty easy job to install.. my first DIY on my car (and any car for that matter).
the sideskirts are a bitch though, you need ot use a lot of force to push em off.
I just installed my oem kit couple days ago... like da top post says da side skirts gotta use some muscle to slide dem off... da front u dont have to take off ur bumper... gotta unscrew two screws on both sides and one in da middle(nose) of da stock lip.... den after dat its those bitch ass pop tab crap things... those were a bitch if u ask me... da back is hella easy compared to everyting else.. hope dat helped some... end result...
Sig Rho's Finest
my sides were real easy, instead of sliding the thing i just pulled the bitch off. the clips got stuck on the car and i used a needlenose pliar to pull em off
BlingBling INSPIRE 32V
Here are the instruction.
Front
http://www.acurainspired.com/forums/...pe=post&id=118
Rear
http://www.acurainspired.com/forums/...pe=post&id=120
Sides
http://www.acurainspired.com/forums/...pe=post&id=119
Good luck!
Front
Rear
Sides
Good luck!
My clips stayed on my original side skirts though and kinda dented the square holes on the car body (just a little "outee" that I gently tapped back into place)...
I think the paint cracked a slightly on a couple of the square holes... Should I worry about rust? I really don't want to take the skirts off to put touch up paint on it if I can avoid it... My thought was that there must be several coats of primer, paint...simply pulling off the original skirts shouldn't expose bare metal...
Thoughts?
After understanding how it all was held in place, the driver's side was easy... I simply took a board, placed it up against the back end of the skirt and gave the board a whack with a hammer... The original skirt came off easily, and with no damage...
Mr. 2tone
actually...the front was frusterating...kuz there were 2 gormets...1 on each side...like the ones towards the middle...yea...we couldnt get them to pull out...so we just ended up snapping them off...but im just gona go to the dealership in the coming days to order new 1s n my type-s TB...
Drive fast & swerve
Originally Posted by InspireUA5
USD$400 with painted and shipped??
where did you buy it?
Is the 02~03 body kit for 400$ too?
cycdaniel
12-17-2019 10:58 AM
pistacio
09-26-2015 09:45 AM
